A mechanic friend asked me to call down and scan a 2006 Seat Toledo (UK RHD), as the dash was lit up like a Christmas tree. The car had been in a minor accident (side impact at front passenger wheel area), where the front passenger side wing, headlight and bumper were damaged. There was minor damage to the chassis behind the wing area, but only to the outer area of it. With the battery being disconnected whilst the car was being repaired, and still currently missing electrical parts as it now gets put back together again, the initial scan was terrible. I've saved a copy of that, and then cleared all the codes, but two (apart from the missing lights etc) remain, and I can't figure out why. None of the airbags deployed, nor did the drivers seat belt tensioner (if one is even fitted). Here is the full scan after clearing all the codes:
Code:
Tuesday,29,October,2019,16:47:51:42449VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
Ross-Tech: Home
VIN: VSSZZZ5PZ6R047425 License Plate: PKZ9296
Mileage: 73660km-45770mi Repair Order: ToledoReset
Chassis Type: 5P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ5PZ6R047425 Mileage: 73660km-45770miles
08-Auto HVAC -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 KL HW: 028 101 292 2
Component: R4 1,9L EDC G000SG 7825
Revision: 12345678 Serial number: SEZ7Z0E3320643
Coding: 0050071
Shop #: WSC 06402 785 00200
VCID: 77FA62DA066895F7A8-8022
6 Faults Found:
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal
Freeze Frame:
RPM: 0 /min
Torque: 122.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00001100
Torque: 0.0 Nm
Torque: 351.4 Nm
18107 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics
Freeze Frame:
RPM: 0 /min
Torque: 122.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 1.0
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 0 /min
Torque: 122.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00001100
Torque: 0.0 Nm
Torque: 351.4 Nm
18049 - Please check DTC Memory of A/C Controller
P1641 - 000 -
Freeze Frame:
RPM: 0 /min
Torque: 122.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00001100
Temperature: 5.4C
(no units): 144.0
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 000 -
Freeze Frame:
RPM: 0 /min
Torque: 122.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Temperature: 7.2C
Temperature: 5.4C
Temperature: 5.4C
17075 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Freeze Frame:
RPM: 0 /min
Torque: 122.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00001100
Temperature: 5.4C
Duty Cycle: 9.6 %
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
VCID: 3F8ACAFA6ED86DB7A0-806A
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
00668 - Supply Voltage Terminal 30
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 5P0 907 044 B
Component: ClimatronicPQ35 006 0203
Shop #: WSC 00000 000 00000
VCID: 2F6A9ABABEB89D3730-807A
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003601434
Coding: 81880F2700041000001E00000100000000007F0B5C
VCID: 2B528EAA8AA0E1171C-807E
Subsystem 1 - Part No: 5P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer SE359 012 0402
Coding: 00056272
Shop #: WSC 06402
3 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01111010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 189
Mileage: 73663 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 189
Mileage: 73663 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 73663 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
Component: S8 AIRBAG VW8 018 2200
Revision: 02018000 Serial number: 0038MD04EBRG
Coding: 0021304
VCID: 3B72BEEA7AC071978C-806E
Subsystem 1 - Serial number: 6332MSME0D4B072CK
Subsystem 2 - Serial number: 6342MSME0D3C5D4DZ
Subsystem 3 - Serial number: 6351HSME09025031U
Subsystem 4 - Serial number: 6361HSME0900650F3
2 Faults Found:
01638 - Crash-Sensor for Side Airbag; Rear Drivers Side (G256)
014 - Defective - MIL ON
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AK HW: 1K0 953 549 AK
Component: J0527 036 0070
Coding: 0002002
Shop #: WSC 67003 476 14504
VCID: 7BF27EEA3A40B197CC-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 005 0060
1 Fault Found:
000 - -
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 5P0 920 923 A
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002401
Shop #: WSC 06403 785 00200
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001059168B53
Coding: 3D3F0340071203
VCID: 2A5C8BAE855AF81FE7-807E
No fault code found.
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1T0 959 701 C
Component: Tuer-SG 024 2432
Coding: 0000656
VCID: 377AA2DA46E855F768-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 346095D6579EBEEF4D-8060
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000DC2D0005054C5F863000CC
VCID: 79FE64E2307C8387DE-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE No Answer
2 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1T0 959 702 C
Coding: 0000656
VCID: 3878A1E64BF65A8F61-806C
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P2 035 152
Component: Radio BNO 0035
Coding: 0040400
VCID: 67DA329A56C8057738-8032
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2426
Coding: 0000144
VCID: 326C93CEAD8AB0DF5F-8066
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
VCID: 336296CA5290B9D754-8066
End-------------------------(Elapsed Time: 01:52)--------------------------
The one's I'm interested in are these ones:
2 Faults Found:
01638 refers to rear driver's side, and shows as defective. Question 1 is does Defective mean the sensor is faulty and should be replaced? Question 2 is does Drivers Side mean RHD drivers side or LHD drivers side?
01217 shows as Upper Limit Exceeded. Would that possibly be due to a faulty connection to the airbag unit below the drivers seat, following movement as a result of the accident?
