Thread: Temp gauge issues
Results 1 to 10 of 16
  1. Temp gauge issues
    Oct 2019
    Hertfordshire
    I've a new problem since getting the car on the road and that is the temp gauge does not work when the car is running but when the car is off and ignition is turned on only after a long drive the gauge shows working? As soon as I restart the car the gauge goes back to zero again.
    I've changed the sensor, bleed the system I have hot and car air working but I'm really confused why the gauge won't work when the engine is on.
    Any ideas as I've looked on Google and the forums with no luck at all.
    First picture shows temp gauge working with engine off and just ignition on
    Second picture with engine on and running.
  2. Re: Temp gauge issues
    Apr 2017
    London
    Do you have vcds? If so I would check the coolant temp on the measuring block when the engine is off and when the engine is running to see which direction to head for a diagnosis.
    If you don’t have vcds then I suggest you get it. A great tool and you can look at data for the price of a cable from eBay.
  3. Re: Temp gauge issues
    Oct 2019
    Hertfordshire
    Okay thanks I don't have vcds but jumped on ebay and ordered one will look into getting the software too. I'm new to all this vag com electronics stuff so I learning curve on setting this up would it also tell me the fault why my fog lights have stopped working a wonder.
    Sent from my CLT-L09 using Tapatalk
  4. Re: Temp gauge issues
    Apr 2017
    London
    You can get the software for free but it only gives you 1 code and you can’t reset. Worth starting with though.
  5. Re: Temp gauge issues
    Oct 2019
    Hertfordshire
    Okay thanks here the results what it giving me on screen
  6. Re: Temp gauge issues
    Jan 2009
    Birmingham
    35 Post(s)
    clear the codes then see what comes up looks like you coolant temp sensor is the issue
  7. Re: Temp gauge issues
    Oct 2019
    Hertfordshire
    How do you clear the codes with the program?
    It's a new temp sensor put in yesterday.
  8. Re: Temp gauge issues
    Jan 2009
    Birmingham
    35 Post(s)
    what colour was the sensor?
  9. Re: Temp gauge issues
    Oct 2019
    Hertfordshire
    Blue.
  10. Re: Temp gauge issues
    Jan 2009
    Birmingham
    35 Post(s)
    what year is your car ? the updated sensor were green were did you get sensor from was it a 4 pin one was the end oval or square?
  1. Coolant temp gauge and oil temp gauge - FIXED - 1.8 TQS
    By leighmagill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-03-2015, 05:17 PM
  2. Temp Sensor/gauge issues
    By Borab0y in forum Golf MK5 - 2004 - 2009
    Last Post: 06-03-2014, 08:58 PM
  3. Climate/heater control & temp gauge issues
    By Mark Bowen in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-01-2014, 03:51 PM
  4. Audi A4 avant temp gauge issues
    By Jay2013 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-04-2013, 08:42 AM
  5. Fix for Temp gauge issues
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-11-2008, 02:25 PM
