Thread: Front driveshaft issue, confusing help
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 46
  1. Re: Front driveshaft issue, confusing help
    #31
    1836 Post(s)
    They are not right or left hand drive specific, For an X chassis post serial 200 001 APU manual ETKA saya 8D0 407 271 AQ left and and 8D0 409 272 AQ right so when I looked it up at home the other night I got it wrong, trying to do complex stuff on an iPad...
  2. Re: Front driveshaft issue, confusing help
    #32
    Oct 2019
    Hertfordshire
    Okay thanks so drive shaft arrived today with code 8d0 407 271 DL
    Woukd this be the correct part for passenger side for my car so I can go ahead and fit it
    615mm roughly in length
    Sent from my CLT-L09 using Tapatalk
  3. Re: Front driveshaft issue, confusing help
    #33
    1836 Post(s)
    Ohh crap, sorry....
  4. Re: Front driveshaft issue, confusing help
    #34
    Oct 2019
    Hertfordshire
    ? I'm so confused by which I need and length now
  5. Re: Front driveshaft issue, confusing help
    #35
    1836 Post(s)
    I had a look on the system I was using at home (no ETKA at home) and it gets it wrong, it's why I [prefer to use ETKA at work.
  6. Re: Front driveshaft issue, confusing help
    #36
    Oct 2019
    Hertfordshire
    Okay so what should I do? I've compared both the AQ Drive shaft and the DL driveshaft side be side and they seem identical but if we can confirm the correct part and length for the passenger side I can go ahead and repair the problem
    For the time being I've began stripping the passenger side down for repair.
  7. Re: Front driveshaft issue, confusing help
    #37
    1836 Post(s)
    Very few manufacturers or reconditioners specify the length.
  8. Re: Front driveshaft issue, confusing help
    #38
    Oct 2019
    Hertfordshire
    Okay well I measured the gap without driveshaft in place today before removing everything and it was 640mm I'm hoping once it's all back together and the lower arm in the correct place it will be 620mm but if there's a way to confirm what length the passenger should be for my car I can get the right one
    At the moment the lower arm is now back in the correct place I just need to put the hub assembly back on which I will hopefully do tomorrow now.
  9. Re: Front driveshaft issue, confusing help
    #39
    Oct 2019
    Hertfordshire
    All back together measuring 620mm so just need the correct driveshaft as that one I ordered the holes are to small for the diff cup.
  10. Re: Front driveshaft issue, confusing help
    #40
    1836 Post(s)
    The parts system I used gave the one for the 1.6 engine, ETKA shows the correct numbers as 8D0 407 271 (left) and 272 AQ (right)
  1. 2006 2.0tdi Front Driveshaft Cost?
    By flashage in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-12-2016, 07:29 PM
  2. Question VW Polo Mk4 1.2. 12v NSF driveshaft fitting issue
    By Phantome46 in forum Home Tech Shed
    Last Post: 12-03-2016, 01:40 PM
  3. Question Seriously confusing issue
    By MarianneM in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-02-2016, 10:29 PM
  4. Front Driveshaft Inner CV / UJ
    By General_Git in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-05-2015, 09:41 PM
  5. Question is a 170 quattro 2.0tdi front driveshaft the same as a normal 2.0 tdi ??????
    By dervquattro in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-02-2014, 09:02 PM
