Thread: Front driveshaft issue, confusing help
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. Re: Front driveshaft issue, confusing help
    #21
    Oct 2019
    Hertfordshire
    Also just popped to the shed to check the oem upright that broke I just replaced it with another one with the same code highlighted if that means anything
    I do need to check the code on the back off the replacement upright as I only compare the main code but that would not matter surely.
    Sent from my CLT-L09 using Tapatalk
  2. Re: Front driveshaft issue, confusing help
    #22
    Mar 2016
    Minervois, France
    53 Post(s)
    The bolt holds the outer CV joint to the hub. The outer CV joint is driven onto the main driveshaft until the circlip engages. It is pressed off by screwing a tool (or an old hub bolt) into the splined end of the CV joint.
    EDIT: This was posted in response to your post No. 20
    EDIT 2: Correct description of the method of putting CV joint on to shaft.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  3. Re: Front driveshaft issue, confusing help
    #23
    Oct 2019
    Hertfordshire
    okay so it's possible it could off been over tightened causing it to pop off. What is the right tightening spec for the bolt please both sides.
    another question relates to which drive shaft and codes from above as I'm getting confused.
    Above says code 8d0 407 271 DL is left passenger which is the one I've ordered.
    Yet the one removed is 8d0 407 271 AQ right drivers according to above which was on my left passenger side
    So have I ordered the right part 8d0 407 271 DL and the driveshaft 8d0 407 271 AQ I removed from left passenger side was wrong
    Very confusing and if above is true I need to recheck code on right drivers side
  4. Re: Front driveshaft issue, confusing help
    #24
    Oct 2019
    Hertfordshire
    Are these correct in pictures engine is the apu 1.8t 150bhp model
    Which would mean I've been correct the whole time needing the 630mm one and would explain all the problems I've been having
  5. Re: Front driveshaft issue, confusing help
    #25
    Jul 2008
    stoke on trent
    The lower control arm is bolted in to correct hole isn't it?
    The subframe has two different mounting points
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  6. Re: Front driveshaft issue, confusing help
    #26
    Oct 2019
    Hertfordshire
    Quote Originally Posted by olds_kool View Post
    2 mounting points? I would need to check again but from memory it's the one nearest to the hub
  7. Re: Front driveshaft issue, confusing help
    #27
    Mar 2016
    Minervois, France
    53 Post(s)
    Quote Originally Posted by mospin1 View Post
    The hub bolt has nothing to do with your shaft breaking, but FYI, the correct tightening spec is:- M14 bolt: 115 Nm (85 lb-ft) + 1/2 turn. M16 bolt: 190Nm (140 lb-ft) + 1/2 turn.
    I've never managed a 1/2 turn, even with my longest 3/4" drive T-bar and a 3 ft cheater pipe. I've managed about 1/4 turn only, but I've not had a wheel come off.
    Your shaft broke inside the outer CV joint, and if the shaft had been seated correctly, with the circlip engaged, the broken piece have been trapped inside the CV joint, and would not have come out.
    If the shaft you fitted was too short, EDIT: or the suspension parts are incorrectly or wrongly mounted, it is very likely it was partly pulled out of the outer CV joint, disengaging the circlip, as you tightened the flange bolts when assembling it.
  8. Re: Front driveshaft issue, confusing help
    #28
    Oct 2019
    Hertfordshire
    Okay update one problem located lower arm was indeed mounted incorrectly causing it all to sit forward and damaging the driveshaft and drop links
    Sneaky how there's 2 locating holes but thanks for pointing it out and finding that issue.
    Unfortunately I can't confirm if it's fixed the car yet as I'm still awaiting parts but hopefully it will
  9. Re: Front driveshaft issue, confusing help
    #29
    1840 Post(s)
    Yes I have seen that before, I have never been able to work out what the other holes are for. I remember about 20 years ago when we were just staring to see a lot of 8D’s come out of warranty and one of my techs did that, he is buried out the back with the others...
  10. Re: Front driveshaft issue, confusing help
    #30
    Oct 2019
    Hertfordshire
    Lol easy mistake to make I guess when your an learner to the trade my excuse is in and out off hospital and trying to keep doing what I enjoy can make it a challenge at times tho haha. Still will get it fixed ASAP and back on the road.
    Just need to sort out this driveshaft issue as I'm worrying its the wrong one again see above post for details.
    For the UK spec is the passenger n/s, 610mm or 630mm as I've ordered the oem one 610. And need to confirm this as the one I've removed is 8D0 407 271 AQ yet above says 8D0 407 271 DL it's very confusing
    I've been going by the German site but they drive on other side off the road so those pics I put up from there site I'm guessing are pointless to UK spec
  1. 2006 2.0tdi Front Driveshaft Cost?
    By flashage in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-12-2016, 07:29 PM
  2. Question VW Polo Mk4 1.2. 12v NSF driveshaft fitting issue
    By Phantome46 in forum Home Tech Shed
    Last Post: 12-03-2016, 01:40 PM
  3. Question Seriously confusing issue
    By MarianneM in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-02-2016, 10:29 PM
  4. Front Driveshaft Inner CV / UJ
    By General_Git in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-05-2015, 09:41 PM
  5. Question is a 170 quattro 2.0tdi front driveshaft the same as a normal 2.0 tdi ??????
    By dervquattro in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-02-2014, 09:02 PM
