Thread: Front driveshaft issue, confusing help
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
  1. Re: Front driveshaft issue, confusing help
    1841 Post(s)
    Could you private message me your VIN.
  2. Re: Front driveshaft issue, confusing help
    Oct 2019
    Hertfordshire
    Pm'ed thanks
    Sent from my CLT-L09 using Tapatalk
  3. Re: Front driveshaft issue, confusing help
    Mar 2016
    Minervois, France
    53 Post(s)
    Quote Originally Posted by mospin1 View Post
    See pic attached
    That doesn't show whether it's the left or the right side.
    Anyway, if you only changed one side, how about measuring and comparing one side with the other?
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  4. Re: Front driveshaft issue, confusing help
    1841 Post(s)
    From my limited info at home at I get the genuine numbers to be front left as 8D0 407 271 DL and front right as 8D0 407 272 AQ which can be used to convert to alternative manufacturers numbers AS LONG as these companies have got it right, often they don’t. I only trust LÖBRO/GKN
    8D0 407 271 AQ a LÖBRO 301219
    8D0 407 272 AQ a LÖBRO 301222
  5. Re: Front driveshaft issue, confusing help
    Oct 2019
    Hertfordshire
    That's brilliant thanks I've order the right part now it is 617mm
    Also would you know if the lower control arms change in length also mainly the one that connects to the droplink and suspension leg as mine looks to long or are the uprights from a 98 and 99 upright different in height or length where the lower arms connects to the upright hub where the ball joints go in as I've noticed my droplink is sitting at a angle by about 15mm instead off straight? So that's popped the Bush out the link or what can cause that please
  6. Re: Front driveshaft issue, confusing help
    Oct 2019
    Hertfordshire
    Now find an issue with the drop link mine measures 90mm which is for drivers side. I've read online I need the 80mm version for passenger side hence why it sits incorrectly and fails would you know the correct part number /model as there's so many online and they don't list the correct specs /sizes
  7. Re: Front driveshaft issue, confusing help
    #17
    1841 Post(s)
    The "wishbone link" as it is known, the one the strut picks up from, is responsible for the track and was the same from 95>2001 when it changed for the 8E model so as long as what you have is equivalent to 4D0 407 151 P, there should not be a problem.
    The drop links are 8D0 411 317 D left with a blue paint mark and 8D0 411 318 D in yellow, both are 90-mm, I would use the Febi pro kits 19704 and 19702
  8. Re: Front driveshaft issue, confusing help
    #18
    Oct 2019
    Hertfordshire
    Okay that's brilliant info thanks finally getting closer to putting it back on the road unfortunately I'm still waiting on the driveshaft and recovery is slow but I did manage to take apart the old driveshaft that broke to find out what happened or the cause, and I'm definitely stumped on this one what cause this damage /snapped never seen anything like it.
    Pictures attached
  9. Re: Front driveshaft issue, confusing help
    #19
    Mar 2016
    Minervois, France
    53 Post(s)
    Are you sure it was pushed in all the way so that the circlip engaged properly?
    It looks as though all the torque was being carried by the splines between the circlip goove and the end of the shaft.
  10. Re: Front driveshaft issue, confusing help
    #20
    Oct 2019
    Hertfordshire
    I've no idea I was only doing around 10mpg out off a roundabout when it happened.
    The bolt that holds it to the hub was pretty dam tight to remove so must off been torqued up correctly
    But strangely the code of the driveshaft reads 8d0 407 271 AQ
  1. 2006 2.0tdi Front Driveshaft Cost?
    By flashage in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-12-2016, 07:29 PM
  2. Question VW Polo Mk4 1.2. 12v NSF driveshaft fitting issue
    By Phantome46 in forum Home Tech Shed
    Last Post: 12-03-2016, 01:40 PM
  3. Question Seriously confusing issue
    By MarianneM in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-02-2016, 10:29 PM
  4. Front Driveshaft Inner CV / UJ
    By General_Git in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-05-2015, 09:41 PM
  5. Question is a 170 quattro 2.0tdi front driveshaft the same as a normal 2.0 tdi ??????
    By dervquattro in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-02-2014, 09:02 PM
