Thread: Heater control unit - non-AC - 8L0819045C - replacements and/or wiring diagrams?
  1. Heater control unit - non-AC - 8L0819045C - replacements and/or wiring diagrams?
    Nov 2017
    Scotland
    Hi all,
    After much excavation (and thinking it was the blower resistor at fault - which it definitely isn't) I have found that the rotary switch controlling my blower motor speed is broken.
    I can operate the fan speeds by jumpering some of the pins on the plug going in the back of the control unit.
    So, I am in need of a replacement heater control unit.
    Problem - I can't find one anywhere. As of this morning I have tried 8 local breakers, and about the same number of A3 breakers listed on eBay.
    None of them can help - most of them have A/C control units (which are obvs completely different), or they have the unit with only a single push button at the bottom
    (for air recirc, while I have one for air recirc and one for the rear demister). Picture attached/below is the version I have.
    I am not 100% sure but I think the plug "pinouts" are different on the single/dual button units, so it wouldn't even just be a case of inserting my (dual) buttons into a single-button unit.
    I think something similar applies to the equivalent units from Seat Leons - different pinouts.
    So, questions -
    - Has anyone else had to replace this unit, and if so how/where did you source a replacement?
    - Does anyone have a wiring/pinout diagram for the plugs and wiring going to the back of this control unit.
    Thanks VERY much for any help; I'm really stuck on this one.
    Jeroen
  2. Re: Heater control unit - non-AC - 8L0819045C - replacements and/or wiring diagrams?
    Nov 2017
    Scotland
    No? Really?
    Ah well.
    FWIW, I've managed to source a suitable replacement (8L0819045C). Eventually. In Lithuania.
    Trouble is, the vast majority of these cars are apparently aircon ones, mine does not have aircon. The control units are crucially different.
  1. 2005 C6 Avant Comfort Control Unit Wiring
    By basil31 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-07-2018, 02:56 PM
  2. Wiring diagram Help Needed. Convenience Control Unit
    By GeeCee in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2011, 10:55 PM
  3. Heater control unit changes by itself.
    By krisgrant311 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-11-2010, 05:31 AM
  4. Sharan: Dashboard heater temp/fan speed/air flow control unit?
    By di4charles in forum Touran - Sharan - Caravelle
    Last Post: 22-03-2008, 09:04 PM
  5. Passat heater fan & control unit
    By JONDAVIKING in forum Passat - Archive Topics
    Last Post: 22-12-2007, 02:54 PM
