Thread: 09 Phaeton 3.0 TDi - an expensive venture?
  1. 09 Phaeton 3.0 TDi - an expensive venture?
    Aug 2018
    GB
    Hi, I've recently bought a 2009 Phaeton with a 3.0 TDi engine. Bought it privately, everything checked out, no issues what so ever. Last week, upon starting the car from cold it began to misfire / rough idle for approximately 20 seconds every moening. Once the 20 seconds are passed, it settles down and drives without any issues. If I start it when it is warm, no issues here. If I leave for the engine to cool down completely, it'll rough idle again, until I press the gas pedal to around 2k RPM for 10 seconds, then it settles.
    I've connected Carly (always worked like a charm on all Audis and VWs), but no codes regarding the engine. Also, 2 days ago the engine light came on. No limp mode. No loss of power. Drives and pulls without issues.
    Any ideas before I take it to a specialist? I've read on other forums from someone with similar issue and it was a few temp sensors on the coolant / fuel.
  2. Re: 09 Phaeton 3.0 TDi - an expensive venture?
    35 Post(s)
    770 Post(s)
    If the light is on a code is at home so Carly is missing a non OBDII code, for anything below the dealer system ODIS, nothing comes close to VCDS, everting else is a cut price sham.
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  3. Re: 09 Phaeton 3.0 TDi - an expensive venture?
    Aug 2018
    GB
    Thanks Crasher, a trip to the specialist it is then.
  4. Re: 09 Phaeton 3.0 TDi - an expensive venture?
    Aug 2018
    GB
    Managed to get someone to check the car properly and it threw P0101. We erased it to see if it comes back and it did come back along with an engine light as usual. I somewhat have an indication as to the fault, e.g.vacuum leak, MAF, PCV, etc. But don't even know where to start...
    P0101 Mass or Volume Air Flow Circuit Range/ Performance
    PIDs supported 101-20] 1.480261635E9
    Freeze DTC DTCs: 1 MIL: off
    Calculated engine load value (EngineLoad)0.0
    Engine coolant temperature (ECT) 83.0
    Intake manifold absolute pressure (MAP) 121.0
    Engine RPM (RPM) 1305.0
    Vehicle speed (Speed) 60.0
    Intake air temperature (IAT) 32.0
    MAF air flow rate (MAF) 53.91
    Run time since engine start (RunTime) 628.0
    PIDs supported [21-4015.38451969E8
    Fuel Rail Pressure (diesel, or gasoline direct inject)(FRP2)
    46270.0
    Commanded EGR (EGR) 0.0
    EGR Error (EGRE) 36.71
    Barometric pressure (BP) 101.0
    PIDs supported [41-60] 1.154482176E9
    Control module voltage (CMV) 14.26
    Ambient air temperature (AAT) 13.0
    Accelerator pedal position D (APPD) 14.5
    Accelerator pedal position E (APPE) 14.5
    Commanded throttle actuator (CTA) 94.9
  5. Re: 09 Phaeton 3.0 TDi - an expensive venture?
    35 Post(s)
    770 Post(s)
    I would start with an Air Mass Meter. ONLY buy this genuine from a VW dealer or TPS, not even if it says Bosch on the box. If it is the one I think it is, part number 059 906 461 K then these are 209.68
  6. Re: 09 Phaeton 3.0 TDi - an expensive venture?
    Aug 2018
    GB
    The issue was the MAF. After replacing the MAF there were no issues what so ever.
    1 1 0
  1. Please Help Expensive Day
    By rapport25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-02-2013, 11:28 AM
  2. 2.5v6 TDI-expensive to run?
    By The Foot in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-07-2010, 01:44 AM
  3. My new german car venture
    By Benson112 in forum New Member Introductions
    Last Post: 15-06-2010, 08:24 PM
  4. Expensive car!!
    By devsgolf in forum Chat - Completely Off Topic
    Last Post: 11-06-2008, 10:29 AM
  5. Expensive day
    By Dainty in forum Touran - Sharan - Caravelle
    Last Post: 03-03-2008, 10:16 PM
