Thread: 2014 Passat, Intermittent ABS and traction lights and loads of random fault codes.
  1. 2014 Passat, Intermittent ABS and traction lights and loads of random fault codes.
    Oct 2019
    Somerset
    Hi all, hopefully someone can point me in the right direction.
    I have a customers car in with intermittent ABS and traction lights, it's never done it when I've had it though, typical!
    The log is below, my first plan of attack is to inspect the reluctor ring on the rear left and replace the abs sensor. But the amount of fault codes in the Central Electrical module concerns me, along with all the other codes relating to lack of comms and missing messages.
    Anything common, wiring, loss connections etc to look out for?
    Code:
    Wednesday,23,October,2019,10:14:10:52855
    VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
    Data version: 20190930 DS308.0
    Ross-Tech: Home
    VIN: WVWZZZ3CZEE171471   License Plate:
    Mileage: 99850km-62043mi   Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4C 4F 52 53 56 61
              62 69 72 77
    VIN: WVWZZZ3CZEE171471   Mileage: 99850km-62043miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    4C-Tire Pressure II -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CFFB)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 PA    HW: 03L 907 309 AE
       Component: R4 2.0l TDI   H28 9978
       Revision: 41H28---    Serial number: 00000000000000
       Coding: 001D0012040501080000
       Shop #: WSC 77009 210 00000
       ASAM Dataset: EV_ECM20TDI01103L906018PA 003009
       ROD: EV_ECM20TDI01103L906018PA.rod
       VCID: 78BC1F72C31D3C8F9F-802C
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans        Labels: 02E-927-770.clb
       Part No SW: 02E 300 062 B    HW: 02E 927 770 AL
       Component: GSG DSG AG6     521 4017
       Revision: 05652104    Serial number: 00001404230720
       Coding: 0000020
       Shop #: WSC 05311 000 00001
       VCID: 14644BC237B5F8EF13-8040
    Address 03: ABS Brakes        Labels: 3AA-614-109.clb
       Part No SW: 3AA 614 109 AQ    HW: 3AA 614 109 AQ
       Component: J104   C2 450M VDC8 0030
       Revision: --H07---    Serial number: 00000008086347
       Coding: 0008115
       VCID: 7CB403623F2510AFFB-8028
    3 Faults Found:
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00111000
                        Fault Priority: 1
                        Fault Frequency: 13
                        Reset counter: 232
                        Mileage: 97199 km
                        Time Indication: 0
                        Date: 2019.09.08
                        Time: 14:01:03
                 Freeze Frame:
                        Speed: 26.0 km/h
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 12.75 V
                        Bin. Bits: 00011111
                        Count: 26
                        Hex Value: 0x0000
    01325 - Control Module for Tire Pressure Monitoring (J502)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 3
                        Fault Frequency: 54
                        Reset counter: 235
                        Mileage: 97199 km
                        Time Indication: 0
                        Date: 2019.09.08
                        Time: 14:01:13
                 Freeze Frame:
                        Speed: 4.0 km/h
                        Hex Value: 0x0000
                        Voltage: 12.75 V
                        Bin. Bits: 00011111
                        Count: 191
                        Hex Value: 0x0000
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 13
                        Reset counter: 232
                        Mileage: 97199 km
                        Time Indication: 0
                        Date: 2019.09.08
                        Time: 14:01:03
                 Freeze Frame:
                        Speed: 26.0 km/h
                        Hex Value: 0x0000
                        Voltage: 12.75 V
                        Bin. Bits: 00011111
                        Count: 26
                        Hex Value: 0x0000
    Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb
       Part No SW: 7N0 907 426 BT    HW: 7N0 907 426 BT
       Component: AC Manuell    H20 0606
       Revision: 00001002
       Coding: 0010004003
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_ACManueBHBVW36X A01010
       ROD: EV_ACManueBHBVW36X_VW46.rod
       VCID: 075E6C8EBEE34377E6-8052
    4 Faults Found:
    13701376 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Motorsteuergerät - kein Signal/Kommunikation]
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 157
                        Reset counter: 240
                        Mileage: 96543 km
                        Date: 2019.08.14
                        Time: 00:49:51
    13701408 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Diagnoseinterface für Datenbus - kein Signal/Kommunikation]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 5
                        Reset counter: 230
                        Mileage: 99698 km
                        Date: 2019.10.09
                        Time: 13:58:08
    13701456 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 105
                        Reset counter: 240
                        Mileage: 96543 km
                        Date: 2019.08.14
                        Time: 00:49:51
    13701600 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Airbagsteuergerät - kein Signal/Kommunikation --> Fehlende Botschaft [ID] von Airbagsteuergerät]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 21
                        Reset counter: 230
                        Mileage: 99464 km
                        Date: 2019.10.06
                        Time: 15:51:06
    Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
       Part No SW: 3AA 937 087 N    HW: 3AA 937 087 N
       Component: BCM PQ47 M    422 0475
       Revision: BA422001
       Coding: 0008000000000000009800801000006403010088424D81606480C7200041
       VCID: 45C2A686CC6F9167D4-8010
       Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 29041  26  0612
       Coding: 00B795
    9 Faults Found:
    00526 - Brake Light Switch (F)
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 2
                        Fault Frequency: 10
                        Reset counter: 235
                        Mileage: 96999 km
                        Time Indication: 0
                        Date: 2019.09.03
                        Time: 09:25:25
                 Freeze Frame:
                            Term 15 On
                        Voltage: 14.65 V
                            ON
                            ON
                            ON
                            OFF
                            ON
    00778 - Steering Angle Sensor (G85)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 51
                        Reset counter: 230
                        Mileage: 96563 km
                        Time Indication: 0
                        Date: 2019.08.17
                        Time: 08:34:08
                 Freeze Frame:
                            Term 15 On
                        Voltage: 12.50 V
                            ON
                            ON
                            ON
                            OFF
                            ON
    01299 - Diagnostic Interface for Data Bus (J533)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 6
                        Reset counter: 230
                        Mileage: 99698 km
                        Time Indication: 0
                        Date: 2019.10.09
                        Time: 13:58:08
                 Freeze Frame:
                            Term 15 On
                        Voltage: 11.85 V
                            ON
                            ON
                            ON
                            OFF
                            ON
    01309 - Power Steering Control Module (J500)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 230
                        Mileage: 99698 km
                        Time Indication: 0
                        Date: 2019.10.09
                        Time: 13:57:54
                 Freeze Frame:
                            Term 15 On
                        Voltage: 12.30 V
                            ON
                            ON
                            ON
                            OFF
                            ON
    01314 - Engine Control Module
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 54
                        Reset counter: 230
                        Mileage: 96543 km
                        Time Indication: 0
                        Date: 2019.08.14
                        Time: 00:49:53
                 Freeze Frame:
                            Term 15 On
                        Voltage: 11.85 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
    01317 - Control Module in Instrument Cluster (J285)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 108
                        Reset counter: 240
                        Mileage: 96543 km
                        Time Indication: 0
                        Date: 2019.08.14
                        Time: 00:49:53
                 Freeze Frame:
                            Term 15 On
                        Voltage: 11.85 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
    01321 - Control Module for Airbags (J234)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 21
                        Reset counter: 230
                        Mileage: 99464 km
                        Time Indication: 0
                        Date: 2019.10.06
                        Time: 15:51:08
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.35 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
    03789 - Terminal 75 Limp Mode Active
                000 - - - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 6
                        Fault Frequency: 254
                        Reset counter: 240
                        Mileage: 96526 km
                        Time Indication: 0
                        Date: 2019.08.13
                        Time: 11:30:45
                 Freeze Frame:
                            Term 15 On
                        Voltage: 14.80 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
    03678 - Coordinator for Start-Stop Operation
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 161
                        Reset counter: 240
                        Mileage: 96543 km
                        Time Indication: 0
                        Date: 2019.08.14
                        Time: 00:49:51
                 Freeze Frame:
                            Term 15 On
                        Voltage: 11.90 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__108 VW10 HI   2518
       Revision: 27019000    Serial number: 003L7P92XJND
       Coding: 0012344
       Subsystem 1 - Serial number: 6332MTS622370954
       Subsystem 2 - Serial number: 6342MTS620270954
       Subsystem 3 - Serial number: 6351HTS6KM8IRCKR
       Subsystem 4 - Serial number: 6361HTS6O0HQPCKR
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
       Part No SW: 3C9 953 501 CM    HW: 5K0 953 569 AR
       Component: LENKS.MODUL   016 0140
       Revision: FF010042    Serial number: 20140417100022
       Coding: 1992050000
       ASAM Dataset: EV_VW360SteerWheelUDS A03004
       ROD: EV_VW360SteerWheelUDS.rod
       VCID: 76A0114AC9094AFF8D-8022
       Multifunction steering wheel control module:
       Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TK6  H07 0022
       Coding: E30000
    1 Fault Found:
    332564 - Databus
              U1121 00 [008] - Missing Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 6
                        Reset counter: 230
                        Mileage: 99698 km
                        Date: 2019.10.09
                        Time: 13:58:08
    Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb-SRI1
       Part No SW: 3AA 920 970 N    HW: 3AA 920 970 N
       Component: KOMBI         H04 0811
       Coding: 461F01
       Shop #: WSC 05314 115 00001
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
       VCID: 3E30C96AA1B9C2BF95-806A
    1 Fault Found:
    12664832 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
                 Freeze Frame:
                        Fault Priority: 6
                        Reset counter: 240
                        Mileage: 96525 km
                        Date: 2019.08.13
                        Time: 11:29:24
    Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
       Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1642
       Revision:   H55       Serial number: 130414F1000732
       Coding: 462007
       Shop #: WSC 05314 000 00001
       VCID: 7BB6007EFA2B1797F2-802E
    1 Fault Found:
    01336 - Company Data Bus for Comfort System
                014 - Defective - Intermittent
                 Freeze Frame:
                        Fault Status: 00101110
                        Fault Priority: 1
                        Fault Frequency: 78
                        Reset counter: 255
                        Mileage: 96543 km
                        Time Indication: 0
                        Date: 2019.08.14
                        Time: 00:50:55
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
       Component:    IMMO         043 0407
       Revision: 00043000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: 383CDF724B9DFC8F5F-806C
       Subsystem 1 - Part No: 3C0 905 861 J
       Component:    ELV          029 0380
       3C0905861J     ELV          029 0380
    1 Fault Found:
    02825 - Supply Voltage for Electronic Steering Column Lock Motor
                014 - Defective
                 Freeze Frame:
                        Fault Status: 01101110
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 158
                        Mileage: 97403 km
                        Time Indication: 0
                        Date: 2019.09.13
                        Time: 12:52:38
    Address 2E: Media Player 3
    Cannot be reached
    Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
       Part No SW: 3AA 959 701     HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0534
       Revision: 13110009    Serial number: 0008421737
       Coding: 0202B5
       Shop #: WSC 05311 115 00001
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
       ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
       VCID: 74A42B42DF7558EFB3-8020
       Slave Driver:
       Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  005 0503
       Serial number: 00000003957966
       Coding: 010290
    3 Faults Found:
    68102 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN Kombi]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 99698 km
                        Date: 2019.10.09
                        Time: 13:58:00
    68107 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN AirBag]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 19
                        Reset counter: 230
                        Mileage: 99464 km
                        Date: 2019.10.06
                        Time: 15:51:06
    68108 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN MSG]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 163
                        Reset counter: 240
                        Mileage: 96543 km
                        Date: 2019.08.14
                        Time: 00:49:51
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 195    3501
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: 393ADA767097E587A0-806C
    1 Fault Found:
    01316 - ABS Control Module
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 3
                        Fault Frequency: 20
                        Reset counter: 235
                        Mileage: 99759 km
                        Time Indication: 0
                        Date: 2019.10.10
                        Time: 15:12:09
                 Freeze Frame:
                        Voltage: 14.75 V
                            DU
                        Temperature: 21.0°C
                        RPM: 858 /min
                        Speed: 17.0 km/h
                        Speed: 17.0 km/h
                        Count: 0
    Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
       Component:    KSG PQ47 ELV 043 0645
       Coding: 0191020052830E76340494157C085FCE105804
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H05 1501
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 12
                        Reset counter: 230
                        Mileage: 99464 km
                        Time Indication: 0
                        Date: 2019.10.06
                        Time: 15:51:06
    Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.clb
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1642
       Coding: 00000008
       VCID: 6FAE242EBE537B374E-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0004
    Address 52: Door Elect, Pass. (J387)       Labels:| 3C0-959-70X-GEN4.clb
       Part No SW: 3AA 959 702     HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0534
       Revision: 15110009    Serial number: 0008404062
       Coding: 0202B4
       ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
       ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
       VCID: 75A21646D40F41E784-8020
       Slave Passenger:
       Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  005 0503
       Serial number: 00000003954135
       Coding: 010290
    3 Faults Found:
              U1111 00 [008] - -
              [Front CAN Kombi]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 99698 km
                        Date: 2019.10.09
                        Time: 13:58:00
              U1111 00 [008] - -
              [Front CAN AirBag]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 20
                        Reset counter: 230
                        Mileage: 99464 km
                        Date: 2019.10.06
                        Time: 15:51:06
              U1111 00 [008] - -
              [Front CAN MSG]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 159
                        Reset counter: 240
                        Mileage: 96543 km
                        Date: 2019.08.14
                        Time: 00:49:51
    Address 53: Parking Brake        Labels: 3AA-907-801.clb
       Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
       Component: J540 EPB4  VW-86594 0010
       Revision:   H19       Serial number: 00000002215207
       Coding: 0022167
       VCID: 3620D14A41890AFF4D-8062
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 48
                        Reset counter: 235
                        Mileage: 97199 km
                        Time Indication: 0
                        Date: 2019.09.08
                        Time: 14:01:03
                 Freeze Frame:
                        Voltage: 12.80 V
                        Count: 104
                        Speed: 26.0 km/h
                        Hex Value: 0x1260
                        Hex Value: 0x0004
                        Hex Value: 0x0101
    00457 - Central Electronics Control Module / BCM (J519)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 229
                        Mileage: 99584 km
                        Time Indication: 0
                        Date: 2019.10.07
                        Time: 08:10:42
                 Freeze Frame:
                        Voltage: 14.70 V
                        Count: 133
                        Speed: 26.0 km/h
                        Hex Value: 0x1260
                        Hex Value: 0x0004
                        Hex Value: 0x0101
    Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 186 AQ    HW: 1K0 035 186 AQ
       Component: Radio RCD310  006 0119
       Revision: 01000001    Serial number: VWZ1Z2P0286261
       Coding: 01000400040011
       VCID: 75A21646DC0F41E784-8020
    Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
       Component: Batt.regelung H55 1642
       Coding: 030F1859
       VCID: 71AA2256A8676DC758-8024
       Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0180
       Serial number: 41101L22501491085595
    Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
       Part No SW: 7N0 907 383     HW: 7N0 907 383
       Component: Towbar module H09 0120
       Revision: 3A001001    Serial number: ÀÁ006789000000
       Coding: 410C040001000000
       Shop #: WSC 00000 000 00000
       VCID: 73A6285ED27B5FD7AA-8026
    Address 77: Telephone (J412)       Labels:| 5N0-035-729.clb
       Part No SW: 5N0 035 729     HW: 5N0 035 729
       Component: TELEFON       H05 0592
       Revision: 1B001001    Serial number: 00007666167499
       Coding: 0A01000080010101
       ASAM Dataset: EV_UHVUMI 001007
       ROD: EV_UHVUMI.rod
       VCID: 6D923E26BC5F89277C-8038
    End----------(Elapsed Time: 01:41, VBatt start/end: 14.9V/14.8V)-----------
  2. Re: 2014 Passat, Intermittent ABS and traction lights and loads of random fault codes.
    Feb 2021
    Cis
    Hello, help plz pinout 5n0 959 655aa
  3. Re: 2014 Passat, Intermittent ABS and traction lights and loads of random fault codes.
    1841 Post(s)
    You would get better results if you start your own thread and tell us what the car is.
  4. Re: 2014 Passat, Intermittent ABS and traction lights and loads of random fault codes.
    Feb 2021
    Cis
    Passat CC 2012, need erase crash data SR module
  5. Re: 2014 Passat, Intermittent ABS and traction lights and loads of random fault codes.
    1841 Post(s)
    If you Google "air bag ECU reset" you will find a lot of companies that offer this service but you should check with your insurance company to see if they will be happy with this.
  6. Re: 2014 Passat, Intermittent ABS and traction lights and loads of random fault codes.
    Feb 2021
    Cis
    I try read EEPROM...
  1. Please Help Breakdown - fault codes - VW Passat 2014
    By Alfa maverick in forum New Member Introductions
    Last Post: 19-05-2018, 05:03 PM
  2. loads of fault codes, any help greatfull
    By Coops1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-02-2014, 09:44 PM
  3. Question Ongoing Intermittent Traction Control warning light fault
    By charwell in forum Golf MK4 - 1999 - 2004
    Last Post: 11-09-2012, 12:10 PM
  4. 00 Passat- brake fault, abs, traction control lights on
    By rallen043 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-09-2007, 10:53 PM
  5. ABS+Traction Control Lights Intermittent
    By metallicabmw in forum Passat - Archive Topics
    Last Post: 16-02-2007, 12:06 PM
