Thread: Cooling problems
Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
  1. Re: Cooling problems
    #41
    Oct 2019
    Bristol
    I've tried this and still the same.
  2. Re: Cooling problems
    #42
    1840 Post(s)
    For some bizarre reason I have yet to fathom, the stop start system will not work if the seatbelt is not engaged. It is one of those questions I ask that I can't figure out the answer such as "why do you have to put your foot on the brake pedal of an automatic to start the engine when it is already locked in park and putting your foot on the brake disengages the lock?", one of life's mysteries.
  3. Re: Cooling problems
    #43
    Mar 2016
    Minervois, France
    53 Post(s)
    It could just possibly be a fault with the switch on the seat belt anchor then.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  4. Re: Cooling problems
    #44
    Oct 2019
    Bristol
    I think it's to do with the battery coding as I cant code it properly due to it having a halfords battery fitted with no serial number etc
  5. Re: Cooling problems
    #45
    Sep 2008
    The batteries do have to be coded using VCDS, as was mine when I had the garage replace it. My stop/start is also no longer working, but this is due to a neutral position sensor which seems to be a pain to sort out.
  6. Re: Cooling problems
    #46
    1840 Post(s)
    Golf 5 batteries don't need coding...
    The side air bag issue is normally the yellow plug at the front of the seat runner in a box under a carpet flap, it goes high resistance.
  7. Re: Cooling problems
    #47
    Oct 2019
    Bristol
    No airbag problems here. It's a agm battery
  8. Re: Cooling problems
    #48
    Oct 2019
    Bristol
    Further to this the engine idle speed set point keeps changing and can be quite high around 1100rpm even when up to temperature. this is nothing to do with a re gen by the way and it has been re gen'd. Normal or abnormal?
  9. Re: Cooling problems
    #49
    1840 Post(s)
    The rpm will lift if the car moves, even slightly.
  10. Re: Cooling problems
    #50
    Oct 2019
    Bristol
    Completely stationary. wondering if the cold weather is having an impact on this
  1. have anyone had problems with cooling fan?
    By streetfighter-r in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-02-2013, 03:53 PM
  2. Please Help A3 1.9 TDi - Cooling problems
    By Barney688 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-01-2011, 08:53 PM
  3. cooling problems
    By chris T in forum Golf MK4 - 1999 - 2004
    Last Post: 07-02-2010, 07:20 PM
  4. Cooling Fan Problems
    By venter81 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2008, 01:21 PM
