Thread: Cooling problems
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
  1. Re: Cooling problems
    #21
    Oct 2019
    Bristol
    I could do with a cooling diagram or something I think that would help
  2. Re: Cooling problems
    #22
    1841 Post(s)
    I can do that on Monday. Not getting a PM.
  3. Re: Cooling problems
    #23
    1841 Post(s)
    I think it was because I had 925 messages in my inbox....
  4. Re: Cooling problems
    #24
    Oct 2019
    Bristol
    Sorry crasher. I think it's my end it still wont let me send it to you. I sent you an email to your actual email address a few days ago?
  5. Re: Cooling problems
    #25
    Oct 2019
    Bristol
    Had enough gonna scrap it.
  6. Re: Cooling problems
    #26
    1841 Post(s)
    Found your email in my spam folder... keeps happening for some reason.
    Before you jump from the nearest high window, lets just go through a few things.
    The Water pump has been replaced with 03L 121 011 P or a top quality equivalent?
    The thermostat has been replaced with the specific version required for a pre 17/05/10 CAYC engine with a 92°c>107°c type, part number 03L 121 113 B? If you have used an aftermarket version the application needs double checking.
    Does it actually overheat or is it that you feel it is? Note the opening temp of the thermostat!
    Have you made sure the additional electric water pump actually works, they are very prone to failure and don’t always give a fault code?
    Have you watched the temp in measuring blocks to see what it actually is?
  7. Re: Cooling problems
    #27
    Oct 2019
    Bristol
    Well the water pump was replaced with a quality replacement or spec with metal impeller. Fact is I've checked temps in measuring block and it is overheating up to around 117 degrees I've had it maximum. Both thermostats are 92 degrees opening as you stated. One was first line so I changed it for a gates one. The gauge doesnt move from 90 but you can feel it bubbling and you open the expansion tank and off it overflows and bubbles
  8. Re: Cooling problems
    #28
    1841 Post(s)
    Do you know the additional electric water pump on the front of the block is working?
  9. Re: Cooling problems
    #29
    Oct 2019
    Bristol
    Yes this works absolutely fine. After weeks of head scratching I've decided to pull the engine and just put another one in it and transfer over the cambelt from the other one. All the good bits I will sell off it to try and get some money back.
  10. Re: Cooling problems
    #30
    1841 Post(s)
    Remember to either swap the injectors or recode the ECU to the new ones.
  1. have anyone had problems with cooling fan?
    By streetfighter-r in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-02-2013, 03:53 PM
  2. Please Help A3 1.9 TDi - Cooling problems
    By Barney688 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-01-2011, 08:53 PM
  3. cooling problems
    By chris T in forum Golf MK4 - 1999 - 2004
    Last Post: 07-02-2010, 07:20 PM
  4. Cooling Fan Problems
    By venter81 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2008, 01:21 PM
