Thread: Cooling problems
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 50
  1. Re: Cooling problems
    Oct 2019
    Bristol
    I would crasher but it's not letting me. It's a 59 plate
  2. Re: Cooling problems
    Oct 2019
    Bristol
    Maybe I haven't posted enough to send you a PM? Remember seeing this in the small print
  3. Re: Cooling problems
    Oct 2019
    Bristol
    Anyone? At my absolute end with this car!
  4. Re: Cooling problems
    Mar 2016
    Minervois, France
    53 Post(s)
    A long shot. Is it a faulty thermostat, or did you fit it upside down?
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  5. Re: Cooling problems
    Oct 2019
    Bristol
    I've tried 3 different thermostats and it's part of a housing so will only go on one way
  6. Re: Cooling problems
    Mar 2016
    Minervois, France
    53 Post(s)
    Oh dear. Something has to be blocked/obstructed. All I can suggest is to check the cooling circuit bit by bit, starting with the most accessible parts, and not ignoring the highly improbable.
    Not suggesting you're daft, but I have seen components installed with the protective sealing plugs still in place. Not necessarily the thermostat. What other parts have been replaced fairly recently?
  7. Re: Cooling problems
    #17
    Oct 2019
    Bristol
    Ok so I've done the cambelt and water pump, headgasket and thermostat. ive had every pipe off and checked for flow. I've also had it block tested and theres no fault there either
  8. Re: Cooling problems
    #18
    1837 Post(s)
    I missed that you had already done the head gasket, did you have the head refaced? Could you PM me the reg or post the VIN now please.
  9. Re: Cooling problems
    #19
    Oct 2019
    Bristol
    I did send you a reg via email. Will try pm you now. I've now flushed the system twice and fitted a new radiator. the fault still persists
  10. Re: Cooling problems
    #20
    Oct 2019
    Bristol
    PM.sent
  1. have anyone had problems with cooling fan?
    By streetfighter-r in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-02-2013, 03:53 PM
  2. Please Help A3 1.9 TDi - Cooling problems
    By Barney688 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-01-2011, 08:53 PM
  3. cooling problems
    By chris T in forum Golf MK4 - 1999 - 2004
    Last Post: 07-02-2010, 07:20 PM
  4. Cooling Fan Problems
    By venter81 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2008, 01:21 PM
