Thread: Jerking at low RPMs and low gears
  1. Jerking at low RPMs and low gears
    Oct 2019
    Sweden
    Hello, new here. I've a 2.0 -00 and for some time it has been jerking while at low RPMs and low gears(1,2 and 3). I've looked it up on the web and it seems like a common problem. But haven't really seen a solution for it. I mean, it can be lots of things. Air leaks, ignition problems etc. Just wondering if someone has experienced this and found a solution or knows what could cause this.
    I found a fault code "16518 - Oxygen (Lambda) Sensor B1 S1: No Activity P0134 - 35-00 - Intermittent". I cleared it and it didn't come back. Could that have something to do with it or is it unrelated?
    Any help is appreciated. It's kinda annoying
  2. Re: Jerking at low RPMs and low gears
    Oct 2019
    Sweden
    Looks like I've found the culprit. Took it for a drive with VCDS and it misfires on Cyl. 2. So it should be the plug or the lead. I'll report back
  3. Re: Jerking at low RPMs and low gears
    Oct 2019
    Sweden
    Well, the misfires jumped to Cyl.1 and 3 after I changed the plug. hmm.. thinking it's the coil pack
  4. Re: Jerking at low RPMs and low gears
    Oct 2019
    Sweden
    Well, it was the spark plugs. Changed them all and it went away
  1. A6 C6 2.0TDi automatic. Struggling at low RPMs
    By JoeAudi16 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-09-2015, 04:13 PM
  2. engine idle rpms correction
    By didkobandita in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-06-2014, 01:35 PM
  3. Unstable RPMs when idle - '04 3.0TDi
    By q_max in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-11-2013, 02:33 PM
  4. Does anyone know the standard RPMs?
    By Kookoo in forum Polo - Derby - Lupo - Fox
    Last Post: 12-01-2008, 02:58 AM
  5. TDI normal rpms when idling?
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 01:22 PM
