Thread: A6 2012 door wont open from outside
  1. A6 2012 door wont open from outside
    Dec 2007
    Dudley, West Midlands
    15 Post(s)
    Hi, had my A6 BiTDi back today, 5 weeks since it broke down with turbo problems to find the drivers door handle does nothing, i had to open the door from the inside to get the drivers door open. Is this an easy fix? Or yet another warranty claim.....
    its a 2012 with keyless entry, all the other doors open from outside.
    Regards Dean Warren. VCDS owner/user
    Audi A6 Avant 2.5 TDi (AAT 115BHP) 305k Sold
    A6 180 sport 2.5 TDi Quattro Avant 2001. Half Leather 160K New Cams Fitted @ 154K
    A6 C6 3.0 TDi Quattro S-Line Avant with Exclusive Leather SatNav Bluetooth AMI LED and Xenon's
  2. Re: A6 2012 door wont open from outside
    May 2014
    Darlington
    76 Post(s)
    The C6 used to suffer the same fault, would have hoped it was fixed on the C7.. Anyway it's most likely the door lock, the micro switches fail inside so the only option is to replace. If you have a warranty on the car just get them to replace it.
  3. Re: A6 2012 door wont open from outside
    Dec 2007
    15 Post(s)
    Thanks, a little disappointed how many times this car has been back to the dealer for problems. This will be 6th warranty claim since i brought it in June.
  4. Re: A6 2012 door wont open from outside
    Jan 2016
    Bridgend Wales
    Iíve just repaired this same problem on my 2007 A8. Very common issue across all vag group cars.
    I stripped my lock down,stripped the bigger of the 2 motors that controls the arm that allows you to unlock.
    Checked the resistance across the motor, and there was dead spot.
    Stripped the motor apart and cleaned the commutator .
    This fixed the issue with dead spot in the motor, and has worked ever since.
  5. Re: A6 2012 door wont open from outside
    Dec 2007
    15 Post(s)
    Suddenly started working again!
  1. Driver door handle wont open door broken ....pulley rod....help !
    By Sam James in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-04-2019, 01:10 PM
  2. door wont open?
    By markoA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-04-2014, 03:32 PM
  3. Question Door wont open
    By indyandy in forum Golf MK4 - 1999 - 2004
    Last Post: 02-10-2012, 05:14 PM
  4. I have a door that wont open!!!!!
    By MrJBerg in forum Golf MK4 - 1999 - 2004
    Last Post: 06-06-2011, 01:09 PM
  5. door wont open
    By jonnyloppy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-02-2011, 06:56 PM
