Thread: Cant start the engine. SAFE on Dashboard
  1. Cant start the engine. SAFE on Dashboard
    Jul 2015
    BG
    I have the car for well over 8 years. Once or twice a year when I try to start the engine nothing happens and it says SAFE on the dashboard. The only solution to this is to remove the positive terminal from the battery for 30 seconds. This is what I get with VCDS immediately after the issue occurred. Any ideas on where the issue is, I think that after 8 years it is time to be fixed.
    Thursday,17,October,2019,05:26:30:07547
    VCDS Version: 19.6.2.0
    Data version: 20190930 DS308.0
    www.Ross-Tech.com
    VIN: WAUZZZ4F45N084976 License Plate:
    Mileage: 262260km-162960mi Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56
    61 62 72 76
    VIN: WAUZZZ4F45N084976 Mileage: 262260km-162960miles
    02-Auto Trans -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: Malfunction 0010
    07-Control Head -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: 059-907-401-ASB.clb
    Part No SW: 4F0 910 401 L HW: 4F0 907 401 A
    Component: 3.0L V6TDI G001AG 0040
    Revision: --H01--- Serial number:
    Coding: 0011772
    Shop #: WSC 02334 785 00200
    VCID: 251AB872DBADAEB3C9-8070
    2 Faults Found:
    17426 - Intake Manifold Runner (Bank 2)
    P1018 - 001 - Lower limit not reached - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 167.7 Nm
    Speed: 0.0 km/h
    Voltage: 12.08 V
    Duty Cycle: 20.5 %
    Duty Cycle: 88.8 %
    Duty Cycle: 20.5 %
    Temperature: 39.6∞C
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 000 -
    Freeze Frame:
    RPM: 0 /min
    Torque: 234.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 10.94 V
    Bin. Bits: 00001111
    Torque: 1035.3 Nm
    Torque: 93.6 Nm
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F0 910 156 H HW: 09L 927 156
    Component: AG6 09L 3.0lTDI RdW 0080
    Revision: --H01--- Serial number: 0071184
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 2819BE7BC7A29C46E1-807C
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
    Component: ESP8 quattro H03 0010
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020872
    VCID: 261BBA7DDFA8A048F1-8072
    Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
    Part No SW: 4F0 910 852 B HW: OOOOOO
    Component: FBSAUDIC6 ELV HO 0130
    Revision: 00HO000 Serial number: OOOOOOO
    Coding: 1068816
    Shop #: WSC 69711 039 133602
    2 Faults Found:
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 0
    Time Indication: 0
    02084 - Component Protection
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 0
    Time Indication: 0
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350L.047555586
    Coding: 0010005
    Shop #: WSC 00000 000 08192
    Subsystem 1 - Part No: 4F0 910 609
    Component: Bedienteil MMIC6H07 0870
    Subsystem 2 - Serial number: 00000000085965
    Subsystem 3 - Serial number: 0129.11.040000000100010360ˇ
    Subsystem 4 - Serial number: 010360ˇ
    1 Fault Found:
    02095 - Component Protection Active
    000 - -
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 262260 km
    Time Indication: 0
    Date: 2005.02.04
    Time: 18:43:23
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 HW: 4F1 820 043 H
    Component: KLIMABETAETIGUNGH11 0110
    Revision: 00000024 Serial number: 00000000094332
    Coding: 0000022
    VCID: 5B54541C33A3623D19-800E
    2 Faults Found:
    01858 - Air Outlet Sensor; Right Center (G348)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 262181 km
    Time Indication: 0
    Date: 2005.02.02
    Time: 01:20:23
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 262260 km
    Time Indication: 0
    Date: 2005.02.04
    Time: 18:43:34
    Freeze Frame:
    Bin. Bits: 00001111
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H17 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0014121
    Shop #: WSC 02335 758 00200
    VCID: 312EA09EEBF16607A9-8064
    Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H05 0150
    Coding: 00064784
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH10 0050
    Coding: 00139600
    Shop #: WSC 02335
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 262136 km
    Time Indication: 0
    Date: 2005.02.04
    Time: 18:43:00
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBD6041811
    Shop #: WSC 00000 000 00000
    VCID: 1C15D65F379EE4F201-8048
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 262260 km
    Time Indication: 0
    Date: 2005.02.04
    Time: 18:43:34
    Address 15: Airbags Labels: 4F0-910-655-8R.clb
    Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
    Component: 32 AIRBAG AUDI8RH29 0250
    Revision: 05H29000 Serial number: 0037LD04Z838
    Coding: 0013106
    Shop #: WSC 30522 264 67890
    Subsystem 1 - Serial number: 6332CSME08072259.
    Subsystem 2 - Serial number: 6342CSME080D46182
    Subsystem 3 - Serial number: 6351HSME05410418X
    Subsystem 4 - Serial number: 6361HSME057D57038
    Subsystem 5 - Serial number: 6371VSME0728605AL
    Subsystem 6 - Serial number: 6381VSME073112042
    1 Fault Found:
    000 - -
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenks‰ulenmodul H07 0230
    Revision: 00H07000 Serial number: 90026043400169
    Coding: 0002141
    Shop #: WSC 02323 785 00200
    VCID: 665B3A3DDFE82088F1-8032
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: Lenkradmodul H06 0080
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 A HW: 4F0 920 900 S
    Component: KOMBIINSTR. M73 H10 0630
    Revision: 00000000 Serial number: 4R750A8D4
    Coding: 0001103
    Shop #: WSC 00001 001 00001
    VCID: 1E13CA453F90D08031-804A
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 262260 km
    Time Indication: 0
    Date: 2005.02.04
    Time: 18:43:30
    Address 19: CAN Gateway Labels:. 4F0-910-468.clb
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
    Component: Gateway H09 0030
    Revision: 09 Serial number: 0800804B2603A4
    Coding: ECFE53C41B2104
    VCID: 2718BC78C3A79A41F9-8072
    2 Faults Found:
    008 - Implausible Signal
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 262260 km
    Time Indication: 0
    Date: 2005.02.04
    Time: 18:43:29
    000 - -
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 262260 km
    Time Indication: 0
    Date: 2005.02.04
    Time: 18:43:24
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
    Component: MNS ECE H43 1060
    Revision: 00000000 Serial number: 353LX047595035
    VCID: 3B3494BCB30322DD19-806E
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
    Component: TSG FA H10 0020
    Revision: 00000000 Serial number: Ñ"7
    Coding: 0000522
    Shop #: WSC 02327 785 00200
    VCID: 2926B066CBD9965FE9-807C
    Address 46: Central Conv. Labels:. 4F0-910-289.lbl
    Part No SW: 4F0 910 289 D HW: 4F0 907 289 D
    Component: Komfortgeraet H14 0090
    Revision: 00900014 Serial number: 01001812680000
    Coding: 0000133
    Shop #: WSC 02335 785 00200
    VCID: 2B24B46CF3D3826D99-807E
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 262260 km
    Time Indication: 0
    Date: 2005.02.04
    Time: 18:43:30
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 G HW: 4F0 035 223
    Component: Amp.-ASK H09 0350
    Revision: 16S00001 Serial number: 01111040046411
    Coding: 0000002
    VCID: 221FC2492FBCB8ACD1-8076
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 262260 km
    Time Indication: 0
    Date: 2005.02.04
    Time: 18:43:30
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280
    Component: ILM Beifahrer H09 0050
    Revision: Serial number: 00000000035301
    Coding: 0001003
    VCID: 5E534A053FD050C031-800A
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 262136 km
    Time Indication: 0
    Date: 2005.02.04
    Time: 18:43:00
    Freeze Frame:
    Voltage: 11.900 V
    Temperature: 21.0∞C
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
    Component: TSG BF H10 0020
    Revision: 00000000 Serial number: y%7
    Coding: 0000522
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 HW: 4F0 907 801
    Component: EPB C63C0030 H03 0030
    Revision: C63C0030
    Coding: 0000321
    VCID: 5D52481A3BD55ECB09-8008
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541
    Component: TUNER EU/US/RDW H41 0630
    Revision: 00000000 Serial number: 352LX047582733
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: ENERGIEMANAGER H11 0490
    Revision: 00000000 Serial number: 00000000090782
    VCID: 231CC474D3BBB2A5D9-8076
    Subsystem 1 - Part No: 000 915 105 DL
    Component: von VA0 310618108C
    Coding: 303030393135313035444C56413033313036313831303843
    Shop #: WSC 00011 888 06946
    1 Fault Found:
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 219
    Mileage: 262260 km
    Time Indication: 0
    Date: 2005.02.03
    Time: 22:56:51
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
    Component: TSG HL H09 0010
    Coding: 0000002
    VCID: 2A27B261CFD4885491-807E
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
    Component: TSG HR H09 0010
    Coding: 0000002
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 HW: 4F0 919 283
    Component: Parkhilfe 4-Kan H09 0030
    Revision: --.--.-- Serial number: 11720432401047
    Coding: 0001006
    VCID: 615E400E2BC146D729-8034
    End-------------------------(Elapsed Time: 02:30)--------------------------
  2. Re: Cant start the engine. SAFE on Dashboard
    May 2014
    Darlington
    78 Post(s)
    Your issue is with module 05 which is the main security module for the car, and for some reason it's gone into component protection (CP), and if that has gone into CP it will activate CP on other modules like the gateway and the instrument cluster.. That will need to be removed using a licensed version of ODIS which is the Audi dealer diagnostic tool, it will also need to have access to the Audi servers, the ebay hacked ODIS tools won't remove CP. Some 3rd party garage have ODIS but not many, also CP cannot be removed via VCDS or VCP etc.
    Coding: 1068816
    2 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 0
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 0
    Time Indication: 0
  3. Re: Cant start the engine. SAFE on Dashboard
    Mar 2009
    Montenegro
    13 Post(s)
    For me it looks like that modul which is responsible for supplying information about car's VIN is faulty as all modules has active CP until they get right information i.e. until you reset that responsible module by cutting the power.
    Sent from my Redmi Note 7 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  4. Re: Cant start the engine. SAFE on Dashboard
    May 2014
    Darlington
    78 Post(s)
    That's the 05 module. There are two modules on the A6 that cause other modules to go into CP, first is the "05-Acc/Start Auth" second is the "19-CAN Gateway" however changing the can gateway would not put the 05 module into CP.
    Also look HW label, revision & serial number something has gone very wrong with this module.
    Coding: 1068816
  5. Re: Cant start the engine. SAFE on Dashboard
    Jul 2015
    BG
    @B5NUT many many people were looking at this scan but you are the first one to notice it. Thank you.
    Any ideas on how to fix it. I can take it to the dealership or I can take it to a shop and they can flash it to the newest version, or maybe I should replace the whole module.
  6. Re: Cant start the engine. SAFE on Dashboard
    May 2014
    Darlington
    78 Post(s)
    Unless someone has been playing around with that module already, then it looks like its faulty and needs to be replaced. You could ask about flashing it however if there is a hardware fault which causes it to fail in the same way then your back to a dead car. Personally if it was my car I would see if you can find some local with a genuine version of ODIS and get a replacement unit, then get CP removed. If you cannot find someone local then the car will need to be recovered to your local Audi dealer and they will replace the Auth/start module and remove CP.
  1. cluster in safe mode. wont start
    By deano1978 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-02-2021, 09:44 AM
  2. Question Safe Mode on start up?
    By askcjj in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-11-2013, 07:27 PM
  3. cluster in safe mode. wont start
    Last Post: 04-03-2013, 08:51 AM
  4. Dashboard lights flashing on ignition, disappear on engine start
    By Steve- in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-05-2012, 12:38 PM
  5. Safe engine?
    By simondhopkins in forum Golf MK3 - 1993 - 1999
    Last Post: 23-12-2009, 12:00 PM
