Thread: Polo 1.4 tdi Temp rising. New thermostat. Still getting hot. 64 reg
  1. Polo 1.4 tdi Temp rising. New thermostat. Still getting hot. 64 reg
    Dec 2016
    uk
    The temperature gauge on my wife's 64 reg Polo 1.4 tdi is going above 12 o clock. When she puts the heaters on it comes down. The fan is kicking in ok. Hose from radiator staying cold. My local mechanic (good guy) checked it and suggested thermostat as first possible issue. Stat changed but problem remains. He reckons that the next step is the water pump. I rate the guy but wanted to see if anyone else has had the issue. Apparently the stat supplier and VW said that faulty / failing stats are not uncommon. However, in our case it doesn't seem to have been the problem. All ideas would be appreciated thanks
  2. Re: Polo 1.4 tdi Temp rising. New thermostat. Still getting hot. 64 reg
    Dec 2016
    uk
    Waterpump. It has a sliding sleeve that stops the waterpump from working. I assume that this is to get the car hotter quicker. Except that it requires the sleeve to move backwards and forwards regularly. And there is the problem.
  1. Oil Pressure Light on and oil temp not rising 02 AWX 1.9tdi
    By tone35 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-11-2012, 10:10 AM
  2. temp rising and stays at about 100degrees
    By jases8 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 28-02-2011, 11:08 PM
  3. Question Water temp not rising above 60 on A3 1.9TDI
    By Mustang003 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 09-11-2009, 03:52 PM
  4. Thermostat Housing/Temp Switch renewal? Polo 1.4 99 V
    By DaveX19 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-06-2009, 08:44 AM
  5. Please Help A3 heater very slow and temp gauge rising very quicly when cold.
    By lamont7615 in forum Audi A3 - Archive Topics
    Last Post: 23-02-2009, 01:49 PM
