Thread: Pedestrian Protection system & adaptive cruise control help
  1. Pedestrian Protection system & adaptive cruise control help
    Oct 2019
    Scotland
    The protection system was set off on my 2016 Q7, i’ve ordered new hinges but will i need to replace any of the impact sensors? Also can i reset the system using VCDS?
    Next question is the the ACC, is it possible to calibrate this at home? Im fairly new to vcds so just finding my way around it.
    Thanks in advance.
  2. Re: Pedestrian Protection system & adaptive cruise control help
    Mar 2010
    37 Post(s)
    228 Post(s)
    Hi there, welcome
    You can't reset ACC at home, it needs calibration at a dealer unfortunately but fairly common to do and takes about an hour. It can't be done with VCDS
    Not aware of other impact sensors, there is one right behind the audi rings on the front grille but thats the impact sensor to trigger the airbags so if your airbags didnt go off (which I assume they havent) it should be fine
    Best answer - you have VCDS, plug it in and do a full scan. Any impact sensor that needs replacing will be flagged under a DTC
    Andy
  3. Re: Pedestrian Protection system & adaptive cruise control help
    Oct 2019
    Scotland
    Hi Andy, Thanks for your reply, much appreciated. I will do a full scan tomorrow and see what it says.
  1. Replies: 9
    Last Post: 17-02-2016, 06:59 PM
  2. Question Adaptive Cruise Control
    By clockwork in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 17-03-2015, 10:18 AM
  3. Pedestrian Protection System
    By pxr5 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 21-11-2014, 11:39 AM
  4. Adaptive cruise control - Is it available?
    By WiiJeff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-09-2007, 06:58 PM
  5. Adaptive cruise control - Available???
    By WiiJeff in forum Passat - Archive Topics
    Last Post: 11-09-2007, 03:05 PM
