Thread: Guidance on oil leak in Audi A4 B8 2.0l CAGA TDI engine (with photos)
  1. Guidance on oil leak in Audi A4 B8 2.0l CAGA TDI engine (with photos)
    May 2016
    Dublin
    Hi Folks,
    I was wondering if anyone had any experience with the following.
    I was changing the oil on my 2008 Audi A4 B8 TDI CAGA 2.0l saloon when I notices that there appeared to be oil on the sump.
    One was localised near the drain bolt so I wasnt worried about that, I can just make sure to tighten the bolt.
    However, it looks like it is coming from higher up.
    Previously I had a leak that I tracked down with the help of this forum to the EGR valve and throttle body. I replaced both along with the inlet manifold and gaskets that appeared to have stopped it. Unfortunately, it looks like I have another now.
    In the time being, I was going to powerwash the underside and leave it for a day or two to see if I can see more easily where the leak is coming from.
    IMG_20191012_182935_out.jpgIMG_20191012_182939_out.jpgIMG_20191012_182946_out.jpgIMG_20191012_182953_out.jpgIMG_20191012_183004_out.jpg
    Thanks!
  2. Re: Guidance on oil leak in Audi A4 B8 2.0l CAGA TDI engine (with photos)
    Nov 2019
    Peterborough
    I have the exact same issue with my Audi B8 2.0 TDI. Did you manage to find what was causing this?
  3. Re: Guidance on oil leak in Audi A4 B8 2.0l CAGA TDI engine (with photos)
    May 2016
    Dublin
    Hi! No, I am afraid not. I havent got around to cleaning the underside yet to see where the oil starts coming from but I will soon.
  4. Re: Guidance on oil leak in Audi A4 B8 2.0l CAGA TDI engine (with photos)
    Nov 2019
    Peterborough
    Hi! Sure, I will probably do the same. I have attached a video of my leak anyhow. https://streamable.com/tgnwc
  5. Re: Guidance on oil leak in Audi A4 B8 2.0l CAGA TDI engine (with photos)
    Mar 2009
    Montenegro
    13 Post(s)
    Look around oil filter housing. There are sensor, cooler (which is dry on film), oil supply pipe to turbo and complete housing to engine block.
    Sent from my Redmi Note 7 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
    By SchrodingersCat in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-04-2020, 09:43 AM
  2. CAGA engine timing display in VCDS
    By caldirun in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-07-2016, 07:48 PM
  3. Please Help Newbie seeking guidance with leak on Audi A3
    By Thfcpad in forum New Member Introductions
    Last Post: 21-07-2015, 09:11 AM
  4. 2.0 tdi caga engine code
    By rchads89 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-04-2015, 10:05 PM
  5. Please Help Ecu Engine a4 2.0tdi CAGA
    By pittyxp in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-08-2012, 05:43 PM
