Thread: Dpf readings
  1. Dpf readings
    Feb 2019
    Hi everyone. Recently bought a 2.0td touran from a dealer and the dpf light has been on a bout 10 times in three weeks.
    Done a vcds scan and came up with the values below but i dont know what they mean. Can someone please help and tell me weather the dpf is on its way out so i know to take it back to the dealer. Many thanks
    PF Load coefficient 20%
    PF carbon mass 55.7
    Carbon mass learned value -18.3
  2. Re: Dpf readings
    Oct 2017
    London
    12 Post(s)
    Think I replied to this post somewhere else in this forum. Readings are too high, as Crasher said best to get it cleaned.
  3. Re: Dpf readings
    Aug 2020
    Lancaster
    Wurth do a dpf cleaner.
    You spray it directly into the dpf and leave it to soak.
    Then burn it off with a hot run.
    I used it on my Leon after i had a faulty anti shudder valve which was acting like a choke. Worked well.
  1. mpg readings
    By vwturbo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-12-2010, 08:29 PM
  2. Vag com MAF readings
    By T.sport in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 13-10-2009, 03:39 PM
  3. vag com readings
    By jet in forum Golf MK3 - 1993 - 1999
    Last Post: 10-09-2009, 08:46 PM
  4. Map readings
    By afire in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-05-2009, 05:15 PM
  5. What Maf Readings Should I Be Getting
    By PETER G in forum VCDS - General Questions
    Last Post: 20-04-2009, 09:46 PM
