Thread: Dpf problem
  1. Dpf problem
    Feb 2019
    Hi everyone. Recently bought a 2.0td touran from a dealer and the dpf light has been on a bout 10 times in three weeks.
    Done a vcds scan and came up with the values below but i dont know what they mean. Can someone please help and tell me weather the dpf is on its way out so i know to take it back to the dealer. Many thanks
    PF Load coefficient 20%
    PF carbon mass 55.7
    Carbon mass learned value -18.3%
  2. Re: Dpf problem
    Oct 2017
    London
    12 Post(s)
    Your carbon mass figure is very high at 55.7g I think when you hit 60g youll go into limp mode as thats the max. What year is your car and how many miles are on it?
    Are you doing short drives? If the light goes on the cars telling you the dpf is getting clogged up. If its going out again then its regening while the lights on and reaching a point the light will go off. If it goes on again your crossing the threshold back to too high. Ideally you never want the light to go on but short drives will make this very hard.
  3. Re: Dpf problem
    1837 Post(s)
    Your DPF needs to come off and be professionally cleaned.
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Sat Nav problem? Or user problem? Can't select postcode entry.
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-09-2012, 10:41 AM
  3. Replies: 19
    Last Post: 24-12-2011, 09:45 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
