Thread: B9 wirless Apple Carplay
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
  1. Re: B9 wirless Apple Carplay
    #21
    Mar 2013
    Brightlingsea
    8 Post(s)
    Mine arrived today. Haven’t had much time to play with it yet. Wireless Apple CarPlay works. According to the manual the rubber-lined cubby in front of the gear lever should be the wireless charging pad but the phone doesn’t acknowledge that it’s charging. Weirdly it looks as though the 6.5” screen gets an SD card slot but the 8” doesn’t. I would be very disappointed by this if I hadn’t switched all my music from SD card to phone a while back. The nav data was on an SD card in my B8.
    The ‘Passat’ badge where the analogue clock used to be is so tacky - I will miss the clock.
  2. Re: B9 wirless Apple Carplay
    #22
    Feb 2013
    Maidenhead Berks UK
    7 Post(s)
    The brochure stated "additional items of standard equipment: SEL (over SE). It goes on to state that the 8" system etc. is fitted but makes no mention of loss of SD reader and wireless charging so I'm a bit miffed!
  3. Re: B9 wirless Apple Carplay
    #23
    Jul 2018
    What are you guys going to do about the lack of wireless charging? As in, is the dealer going to compensate or do anything?
    I'm going to attempt to retrofit it, but as it's only a 5W charger, I understand it's a very very slow charger.....
  4. Re: B9 wirless Apple Carplay
    #24
    Mar 2013
    Brightlingsea
    8 Post(s)
    Given that the supply chain for my leased car is Employer->GoFinance->VW Finance->VW Dealer I really can't be bothered to try and fight it. Compensation isn't going to make up for it anyway. Of course it may be that the feature is there and I haven't found out where it is or how to enable it yet.
    Going back to the SD card issue, I note that in the brochure the Composition Media Infotainment system (SE trim) does have an SD card reader (and a CD player) but the Discover Navigation Infotainment system (SE-L trim) does not. If you go up to the Discover Pro then you get 2 SD card readers. Go figure!
    If anyone gets a definitive answer on the wireless charging I'd like to know.
    Another point, the USB sockets in the car are now USB-C not A. Mine did come with a short USB-C to A adaptor cable.
    EDIT having opened the packet I find it's a lightning to USB-A cable, which given that the car has only USB-C sockets is of no use at all!
  5. Re: B9 wirless Apple Carplay
    #25
    Mar 2013
    Happy New Year
    How is the wireless CarPlay going ?
    Which iPhone/iOS are you using ?
    Reliable on long trips ?
    Does your phone get hot if navigating and playing on phone content at the same time ? e.g. podcasts
    Reliable re connection when you get back in car ?
    Can you use built-in car nav and play CarPlay audio at same time and can you listen to DAB radio whist navigating with Apple Maps or Waze ?
  6. Re: B9 wirless Apple Carplay
    #26
    Mar 2013
    Brightlingsea
    8 Post(s)
    Happy New Year!
    It’s going well.
    iPhone 8, latest iOS.
    Yes.
    Not that I’ve noticed but haven’t specifically checked.
    Yes.
    Yes. The only combo you can’t use is built-in Nav and ‘phone app Nav at the same time.
  7. Re: B9 wirless Apple Carplay
    #27
    Mar 2013
    Great. I'm glad it is working well for you
    What is the longest drive you have been on and used Wireless CarPlay the whole way ?
  8. Re: B9 wirless Apple Carplay
    #28
    Mar 2013
    Brightlingsea
    8 Post(s)
    Just over a couple of hours (using Google Maps).
  9. Re: B9 wirless Apple Carplay
    #29
    Mar 2013
    Did that drain 50% of your iPhone battery or have you now got a 3rd party wireless charger as your car didn't come with one ? (much to your surprise!?)
  10. Re: B9 wirless Apple Carplay
    #30
    Mar 2013
    Brightlingsea
    8 Post(s)
    Ah, you've got me there - because I was driving to Heathrow for a long haul flight I had the 'phone plugged in to the USB, so maybe it wasn't doing Carplay wirelessly (I wonder what it actually does when both connection types are available). Next time I'm on a reasonable length journey I'll do it wirelessly and see what battery % per hour it sucks up.
    I am wondering whether to get one of these to put in the cubby where the wireless charger is expected to be - it looks thin enough, and looks as though it should contain the 'phone from sliding around and falling off the pad:
    https://www.amazon.co.uk/dp/B07N62X2RD/?coliid=I1TQZQKR2R3V4&colid=2K1A22TXJXSZN&psc=1&re f_=lv_ov_lig_dp_it
  1. Apple carplay installed on non Audi registered Carplay cars
    By inchshort in forum Q7 - 4M Forum - 2016 -
    Last Post: 03-05-2019, 06:44 AM
  2. Q for this with Apple CarPlay
    By a900ss in forum Passat - B8 Forum - 2015 -
    Last Post: 05-05-2018, 07:19 PM
  3. Question Apple CarPlay - Retrofit
    By Sy1441 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 18-02-2018, 11:55 PM
  4. Apple CarPlay
    By Nemo78 in forum Q7 - 4M Forum - 2016 -
    Last Post: 04-08-2016, 11:45 AM
  5. Apple CarPlay
    By bigsteve102 in forum Passat - B8 Forum - 2015 -
    Last Post: 07-03-2016, 09:25 PM
