Thread: Passat B6 both rear speed sensors fault.
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
  1. Passat B6 both rear speed sensors fault.
    Oct 2019
    Lancashire UK
    Hi folks,
    My friend & I are currently baffled by an ABS problem on his B6 (built 2010/registered 2011) 1.6 Passat Bluemotion Estate;
    These are the symptoms:
    a) ABS activating whenever brake pedal operated.
    b) ABS warning light on constantly.
    c) ESP warning light on constantly.
    d) parking brake warning light on constantly.
    e) Engine 'Stop Start' disabled. Warning light comes on when car stops.
    f) Steering wheel warning light comes on temporarily when ignition key removed and 'Steering Lock See Workshop' message appears temporarily.
    Our actions:
    1) Read car with VCDS. Got left rear (l/r) and right rear (r/r) faults along with ESP/parking brake/engine 'stop/start.
    We think the ESP/parking brake/engine 'stop/start faults stem from the sensor faults?
    2) We swapped the left rear sensor for a known good one (used a sensor from a donor car with no issues).
    3) Still both sensor faults.
    4) Removed both rear bearings. Tiny amount of play in one. Both sensor magnetic discs in good condition.
    5) Checked continuity between l/r sensor to ABS module multiplug. Seems ok.
    6) Visually inspected individual wires around ABS module multiplug. No evidence of corrosion. Cleaned with contact cleaner.
    7) Removed ABS module and sent to ECUTESTING. No fault found.
    8) Removed engine management ECU. No evidence of corrosion. The surface of the unit was wet but the plug pins/sockets seemed fine. Cleaned with contact cleaner.
    We're now out of ideas other than a wiring fault somewhere in the loom/s.
    Any ideas from anyone with experience of a two sensor fault will be much appreciated.
    VCDS result below.
    Regards,
    H..
    Code:
    Sunday,01,September,2019,13:43:24:23083
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    Data version: 20190529 DS308.0
    www.Ross-Tech.com
    VIN: WVWZZZ3CZCE028143   License Plate:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 4F 52 53 56 61 62
              72 77
    VIN: WVWZZZ3CZCE028143   Mileage: 190040km-118085miles
    01-Engine -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    61-Battery Regul. -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 FS    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 9196
       Revision: --H43---    Serial number: 00000000000000
       Coding: 00194034030501080000
       Shop #: WSC 00015 115 00000
       ASAM Dataset: EV_ECM16TDI02103L906023FS 003006
       ROD: EV_ECM16TDI02103L906023FS_003.rod
       VCID: 7CA1F6BE666EC557961-8028
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes        Labels: 3AA-614-109.clb
       Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
       Component: J104   C2 450M V466 0022
       Revision: --H07---    Serial number: 00000004280081
       Coding: 0002983
       Shop #: WSC 05311 000 00000
       VCID: 6D87CBFA21945CDF11F-8038
    3 Faults Found:
    03841 - RPM Sensor Rear Left: Incorrect Signal
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 1
                        Fault Frequency: 11
                        Reset counter: 101
                        Mileage: 189952 km
                        Time Indication: 0
                        Date: 2014.01.21
                        Time: 17:17:36
                 Freeze Frame:
                        Speed: 0.0 km/h
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 11.75 V
                        Bin. Bits: 00011111
                        Count: 156
                        Hex Value: 0x0000
    03842 - RPM Sensor Rear Right: Incorrect Signal
                000 - -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 11
                        Reset counter: 101
                        Mileage: 189952 km
                        Time Indication: 0
                        Date: 2014.01.21
                        Time: 17:17:36
                 Freeze Frame:
                        Speed: 0.0 km/h
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00011111
                        Count: 157
                        Hex Value: 0x0000
    01200 - ABS Valves Supply Voltage
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101011
                        Fault Priority: 1
                        Fault Frequency: 9
                        Reset counter: 142
                        Mileage: 189952 km
                        Time Indication: 0
                        Date: 2014.01.21
                        Time: 17:19:41
                 Freeze Frame:
                        Speed: 0.0 km/h
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00011111
                        Count: 170
                        Hex Value: 0x0000
    Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb
       Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
       Component: AC Manuell    H19 0304
       Revision: 00001015
       Coding: 0000004003
       ASAM Dataset: EV_ACManueBHBVW36X A01010
       ROD: EV_ACManueBHBVW36X_VW46.rod
       VCID: 7F5B01B27778DE4FB33-802A
    1 Fault Found:
    9481200 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 250
                        Mileage: 182038 km
                        Date: 2018.06.28
                        Time: 10:25:41
    Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
       Part No SW: 3AA 937 087 C    HW: 3AA 937 087 C
       Component: BCM PQ47 M    413 0455
       Revision: BA413001
       Coding: 000000000000000000180080100000E403010088424D81606480C7200041
       VCID: 3A2D30A62C5A3B67C4D-806E
       Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 23061  26  0612
       Coding: 00B795
    Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
       Part No SW: 3AE 919 475     HW: 7N0 919 475
       Component: PARKHILFE 8K  H04 0009
       Revision: --------    Serial number: 77631117602130
       Coding: 108002
       Shop #: WSC 99999 1023 2097151
       ASAM Dataset: EV_EPHVA18VW47X0000 001003
       ROD: EV_EPHVA18VW47X0000.rod
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__102 VW10 HI   1918
       Revision: 22014000    Serial number: 003K0PDB4L4F
       Coding: 0012338
       VCID: 4CC1667E7ACEB5D7661-8018
       Subsystem 1 - Serial number: 6332MTS626561671
       Subsystem 2 - Serial number: 6342MTS621941661
       Subsystem 3 - Serial number: 6351HTS63LLK7AKJ
       Subsystem 4 - Serial number: 6361HTS60RQJ7AKJ
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
       Part No SW: 3C9 953 501 BF    HW: 5K0 953 569 S
       Component: LENKS.MODUL   014 0140
       Revision: FF010040    Serial number: 20110702201116
       Coding: 1182050000
       ASAM Dataset: EV_VW360SteerWheelUDS A03004
       ROD: EV_VW360SteerWheelUDS.rod
       VCID: 6E85CCF62012A7C7285-803A
       Multifunction steering wheel control module:
       Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TK6  H06 0022
       Coding: E20000
    Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb-SRI1
       Part No SW: 3AA 920 970 E    HW: 3AA 920 970 E
       Component: KOMBI         H03 0607
       Coding: 461F00
       Shop #: WSC 05314 115 00000
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
       VCID: 3537239A05C4D41F29F-8060
    Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
       Part No SW: 7N0 907 530 K    HW: 1K0 907 951
       Component: J533  Gateway H40 1620
       Revision:   H40       Serial number: 260611F2003234
       Coding: 462007
       Shop #: WSC 05314 000 00000
       VCID: 38292AAE12562977329-806C
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         043 0400
       Revision: 00043000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: 76B5E49654C29F07E05-8022
       Subsystem 1 - Part No: 3C0 905 861 J
       Component:    ELV          029 0380
       3C0905861J     ELV          029 0380
    1 Fault Found:
    02823 - Requirements for Locking the Steering Column Lock not met
                000 - -
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 34
                        Mileage: 189302 km
                        Time Indication: 0
                        Date: 2013.11.28
                        Time: 18:42:25
    Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
       Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
       Component: SG EXT.PLAYER H13 0240
       Revision: A1001003    Serial number: 7660361449
       Coding: 010000
       VCID: 290FFFEAD9FC80FFBD7-807C
    Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
       Part No SW: 3AA 959 701     HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0534
       Revision: 13110009    Serial number: 0003063960
       Coding: 0202B5
       Shop #: WSC 05311 115 00000
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
       ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
       VCID: 74B1DE9E4E3E8D17DE1-8020
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0407
       Serial number: 00000002283749
       Coding: 000290
    1 Fault Found:
    66048 - Motor for Front Window Regulator
              B11EC 54 [008] - Missing Calibration / Basic Setting
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 130
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 194    3201
       Revision: 00H20000
       Shop #: WSC 02069 000 90108
       VCID: 34311E9E023ECD171E1-8060
    1 Fault Found:
    01316 - ABS Control Module
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 3
                        Fault Frequency: 7
                        Reset counter: 101
                        Mileage: 189952 km
                        Time Indication: 0
                        Date: 2014.01.21
                        Time: 17:17:36
                 Freeze Frame:
                        Voltage: 11.88 V
                            DD
                        Temperature: 42.0°C
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Speed: 0.0 km/h
                        Count: 0
    Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
       Component:    KSG PQ47 ELV 043 0634
       Coding: 0191020052830E76300494157C085FCE107C01
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H05 1501
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.clb
       Part No SW: 7N0 907 532     HW: 1K0 907 951
       Component: EZE_2         H40 1620
       Coding: 00000008
       VCID: 6FBBD1F22798AECF233-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
    Address 52: Door Elect, Pass. (J387)       Labels:| 3C0-959-70X-GEN4.clb
       Part No SW: 3AA 959 702     HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0534
       Revision: 15110009    Serial number: 0003042772
       Coding: 0202B4
       ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
       ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
       VCID: 75B7E39A4544941FE9F-8020
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0407
       Serial number: 00000002277489
       Coding: 000290
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 130
    Address 53: Parking Brake        Labels: 3AA-907-801.clb
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000084143
       Coding: 0022167
       VCID: 3537239A0944D41F29F-8060
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 254
                        Reset counter: 102
                        Mileage: 189297 km
                        Time Indication: 0
                        Date: 2013.11.28
                        Time: 18:33:24
                 Freeze Frame:
                        Voltage: 12.80 V
                        Count: 104
                        Speed: 46.0 km/h
                        Hex Value: 0x1268
                        Hex Value: 0x8004
                        Hex Value: 0x0101
    Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
       Component: RCD310 EU     H02 5004
       Revision: -----03S    Serial number: VWZ4Z2L1288462
       Coding: 01000400040011
       VCID: 72BDD88634AA8327CCD-8026
    2 Faults Found:
    00870 - Bass Speaker Front Left (R21)
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 183
                        Mileage: 169332 km
                        Time Indication: 0
                        Date: 2017.02.06
                        Time: 17:28:05
    00872 - Bass Speaker Rear Left (R15)
                011 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 151
                        Reset counter: 91
                        Mileage: 169332 km
                        Time Indication: 0
                        Date: 2017.02.06
                        Time: 17:28:05
    Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H40 1620
       Coding: 030B185A
       VCID: 71BFD78A31ACB83F357-8024
       Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900868333
    Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
       Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
       Component: TELEFON       H13 2902
       Revision: 1B001001    Serial number: 00007661849327
       Coding: 0A01000000010101
       Shop #: WSC 00770 210 105474
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 2615F4D6C862AF87905-8072
    End----------(Elapsed Time: 01:32, VBatt start/end: 12.0V/11.9V)-----------
  2. Re: Passat B6 both rear speed sensors fault.
    1840 Post(s)
    There are some low battery voltages shown there if the fault occurred with the engine running.
  3. Re: Passat B6 both rear speed sensors fault.
    Oct 2019
    Lancashire UK
    Thanks Crasher,
    Any idea what I should try next?
    23:56 PM:
    Thanks again Crasher,
    I referred your post to my brother, who has considerable electronic knowledge/experience.
    He then had a look at the VCDS report and supposed/suspected that you might be onto something here.
    The ABS section of the report gave fault code 01200;
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 9
    Reset counter: 142
    Mileage: 189952 km
    Time Indication: 0
    Date: 2014.01.21
    Time: 17:19:41
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 11.75 V
    Bin. Bits: 00011111
    Count: 170
    Hex Value: 0x0000
    Ross-Tech, who developed the VCDS software have this description/explanation for Fault code 01200;
    01200 - Ross-Tech Wiki
    We're now suspecting a supply issue to the ABS module?
    Without a wiring diagram this won't be easy I reckon, so I'm hoping to find:
    1) A wiring diagram.
    2) Any advice on the physical location of any fuses/wiring/connectors between the power supply and the ABS module and any suggestions of where to inspect.
    Regards,
    H..
  4. Re: Passat B6 both rear speed sensors fault.
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by Henry V View Post
    Thanks Crasher,
    Sounds like you may need to check the battery and / or alternator?
    Mad Mitch
  5. Re: Passat B6 both rear speed sensors fault.
    Oct 2019
    Lancashire UK
    Thanks DM,
    The battery seems fine and was starting the car no problem whilst the faults were present.
    The alternator must be ok because it is keeping the battery charged. Also, the battery warning light would be warning that the battery wasn't receiving charge if it was failing. No such symptoms.
    Regards,
    H..
  6. Re: Passat B6 both rear speed sensors fault.
    1840 Post(s)
    I’m with Mitch, the battery would be my first suspect, I have seen many modern batteries and the efficient starter motors used throw people because they crank like everything is OK but the voltage is too low.
  7. Re: Passat B6 both rear speed sensors fault.
    Jan 2012
    10 Post(s)
    87 Post(s)
    Thanks DM,
    Regards,
    H..
    You can view the live data of the voltages in VCDS Measuring Blocks. And, before the car is started the base charge of the battery.
    Mad Mitch
  8. Re: Passat B6 both rear speed sensors fault.
    Oct 2019
    Lancashire UK
    Could anyone tell me where to find fuse S54 on a 2011 Passat?
    I want to check its condition and connection.
  9. Re: Passat B6 both rear speed sensors fault.
    Jan 2012
    10 Post(s)
    87 Post(s)
    Fuse Box Diagram > Volkswagen Passat B6 (2005-2010)
    As side panel fuses do not go up to number 54 it may be SB54 in the engine compartment fuse box - a 50amp fuse for the Glow Plug Control Module?
    Mad Mitch
  10. Re: Passat B6 both rear speed sensors fault.
    1840 Post(s)
    I found the email in my spam folder, I will look a bit deeper at work tomorrow.
  1. rear speed sensors
    By bobfish45 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-05-2014, 03:22 PM
  2. Passat B5 2005 last of old shape - Installing rear parking sensors
    By Faces in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-02-2014, 11:01 AM
  3. Please Help Rear parking sensors - strangle fault, help appreciated!
    By GE90 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-11-2013, 09:37 PM
  4. Fault 00287 - ABS Wheel Speed Sensor: Rear Right
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2013, 08:13 AM
  5. Where are these sensors? O2 - Lambda / MAF / ABS wheel speed rear left
    By p33tew in forum Polo - Derby - Lupo - Fox
    Last Post: 13-11-2008, 12:41 PM
