Thread: Passat B6 both rear speed sensors fault.
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
  1. Re: Passat B6 both rear speed sensors fault.
    #21
    Jan 2023
    Durban, South Africa
    On early cars, 2006>2008 it was standard practice to replace the incompetence [sic] unit.
    Is there anyway to test the CCM?
  2. Re: Passat B6 both rear speed sensors fault.
    #22
    1842 Post(s)
    Really only a fault code scan, have you checked fuse 14 in the dash side fuse board.
  3. Re: Passat B6 both rear speed sensors fault.
    #23
    Jan 2023
    Tested all fuses for continuity and voltages, all are good
  4. Re: Passat B6 both rear speed sensors fault.
    #24
    Jan 2023
    Hi Crasher, just wondering, the red/yellow wire from the CCM to the ESCL, is that supposed to have 12V or is that a ground.
    Tested the wiring and it doesn't seem to have 12 V but if I do a volt test with battery positive and the red/yellow wire, the red/yellow wire is a ground.
    Tested with both CCM and ESCL connected, disconnected, 1 module connected and a time and same results.
  5. Re: Passat B6 both rear speed sensors fault.
    #25
    Jan 2023
    Quote Originally Posted by Chies View Post
    Sorry I am totally hopeless reading the wiring diagrams
  6. Re: Passat B6 both rear speed sensors fault.
    #26
    Mar 2010
    Derry ireland
    60 Post(s)
    Can you post up engine code or your reg no
  7. Re: Passat B6 both rear speed sensors fault.
    #27
    Jan 2023
    Quote Originally Posted by mickeybo View Post
    Hi Mickeybo, engine code CFGB
  8. Re: Passat B6 both rear speed sensors fault.
    #28
    Jan 2023
    Hi Mickeybo, engine code CFGB. My reg no. Probably will not help as the vehicle is registered in South Africa
  9. Re: Passat B6 both rear speed sensors fault.
    #29
    Jan 2023
    Checked fuses again and I am not getting power to a host of fuses
    Main fuse box in engine compartment :
    F10
    F14
    F16
    F18
    F19
    F20
    F23
    F24
    Fuse box in next to steering wheel :
    2
    3
    8
    9
    11
    25
    32
    43,44,45 1.8 volts
  10. Re: Passat B6 both rear speed sensors fault.
    #30
    Jan 2023
    Hi Crasher
    Need help with voltages, from the CCM to the steering column lock there are 2 wires, red/yellow and green/brown.
    Do you know what voltages these wires carry?
    I'm assuming that the red/yellow is +12v and the green/brown is a ground?
  1. rear speed sensors
    By bobfish45 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-05-2014, 03:22 PM
  2. Passat B5 2005 last of old shape - Installing rear parking sensors
    By Faces in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-02-2014, 11:01 AM
  3. Please Help Rear parking sensors - strangle fault, help appreciated!
    By GE90 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-11-2013, 09:37 PM
  4. Fault 00287 - ABS Wheel Speed Sensor: Rear Right
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2013, 08:13 AM
  5. Where are these sensors? O2 - Lambda / MAF / ABS wheel speed rear left
    By p33tew in forum Polo - Derby - Lupo - Fox
    Last Post: 13-11-2008, 12:41 PM
