Thread: central locking
  1. central locking
    Nov 2009
    Forres Scotland
    Hi there I hope someone can help me.
    Someone got in my car while I thought it was locked, turns out my front passenger and rear driver side doors do not lock when the rest of car doors do.
    Any advise on how to fix problem would be much appreciated.
    Ron.
  2. Re: central locking
    1840 Post(s)
    Have the convenience system fault code scanned, it is likely you need two new door lock units.
  3. Re: central locking
    Nov 2009
    Forres Scotland
    ok crasher thank you will see if I can get it scanned.
  4. Re: central locking
    Oct 2017
    London
    12 Post(s)
    Get it scanned and fixed asap before the door doesnt open at all and makes it a lot harder to fix. Only seen that once and never want to see it again. Will be a broken wire or more likely the door module. Very rare you see a Mk5 Golf without a door lock module playing up. Something like this on a scan.....
    2 Faults Found:
    01554 - Motors for Central Locking; Rear Doors; Lock
    012 - Electrical Fault in Circuit - Intermittent
    00931 - Locking Module for Central Locking; Rear Right (F223)
    008 - Implausible Signal - Intermittent
  5. Re: central locking
    May 2017
    Cardiff
    12 Post(s)
    In the mean time, you can manually lock those doors;
    HELP! - MANUALLY Lock Mk5 rear door - Possible?
  1. Golf MK5 1.9 Passenger door not locking with central locking
    By hussnainh8 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-12-2016, 02:25 PM
  2. Question Central Locking Not locking all Doors On Jetta 2006
    By jamiecorbett in forum Jetta MK3 - 2005 - 2013
    Last Post: 04-04-2011, 10:06 PM
  3. Central Locking Not Locking Drivers Door
    By davieb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-11-2008, 10:37 PM
  4. keys, central locking to remote central locking!!!!!!!
    By Shakey mk4 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-03-2008, 01:35 AM
  5. Coverting Central Lockin to Remote Central Locking
    By hoedawg in forum Golf MK4 - 1999 - 2004
    Last Post: 29-12-2007, 05:08 PM
