Thread: BITDI Rhythmic noise at 60mph+; auto ignition off
  1. BITDI Rhythmic noise at 60mph+; auto ignition off
    Oct 2019
    Evesham
    I’ve got a 2016 BITDi estate with ~28000 miles which I’ve had for about 6 months; I really like the car however it has two relatively trivial but annoying niggles:
    the first is that when travelling at 60mph and above there is an annoying rhythmic noise; it seems to oscillate every second and gets More noticeable the faster I go; isn’t gear specific and also happens in neutral. The local dealer thinks it’s stepped tyres however in the past when I’ve had stepped tyres it’s been a constant drone that sounds like a wheel bearing. Has anyone else experienced this?
    the other “feature” is that when I park up and the start stop turns the engine off if I open the drivers door the ignition doesn’t automatically turn off. Previously I had a 2016 golf that automatically turned the ignition off if the engine wasn’t running when the door was opened; my Passat does have keyless. Whilst this is trivial it is annoying and the car beeps when the door is open. Does anyone have a Passat that automatically shuts the ignition off when the door is open? The manual suggestions undoing seatbelt first but seems to make no difference.
  2. Re: BITDI Rhythmic noise at 60mph+; auto ignition off
    Mar 2013
    Brightlingsea
    8 Post(s)
    Mine (2016) bongs and warns the ignition is on if you open the door without pressing the start/stop button to switch it off first. It has keyless stop/start but not keyless entry.
  3. Re: BITDI Rhythmic noise at 60mph+; auto ignition off
    Oct 2019
    Evesham
    Quote Originally Posted by MikeBz View Post
    thanks, exactly the same as mine then. It so trivial but the Golf was better as just had to open the door and automatically turned ignition off
  1. Question Rhythmic knocking noise when braking
    By Engr868 in forum Golf MK5 - 2004 - 2009
    Last Post: 04-06-2018, 09:48 AM
  2. Wheel/Tyre noise from 40mph to 60mph ?
    By silkysmooth in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-04-2015, 04:47 PM
  3. Whistling noise at 60mph
    By kop77audi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-05-2014, 08:58 AM
  4. 2001 Passat 130 TDI sport - rhythmic knocking noise from rear
    By Froggy_130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-08-2011, 08:42 PM
  5. Please Help strange noise over 50-60mph
    By audi bwoy in forum Golf MK5 - 2004 - 2009
    Last Post: 27-06-2011, 05:07 PM
