Thread: B8 Estate rear shock absorbers.
  1. B8 Estate rear shock absorbers.
    Jan 2009
    norwich
    Hi all ! Just found a leaking rear shock … 2015 GT Estate … Questions … 1. Are they easy to change, can it be done from outside ? remove wheel bay lining for top mounting ? or is it from inside ?? 2. Best place to buy in UK etc etc ????
    Keith.
  2. Re: B8 Estate rear shock absorbers.
    Jan 2009
    norwich
    OK Answering my own questions here ... Yes top mount is removed from inside the wheel arch no need to remove the lining !! All very easy !
    I purchased a 'Monroe' shock from GSF ... £52 ... Quick and easy fit !! So much better driving over potholes without the additional 'lump crash' from the rear.
    Keith.
  3. Re: B8 Estate rear shock absorbers.
    Jul 2020
    daventry
    Hi Keith,
    Can you confirm if you had to use any special spanners for removing mount from absorber?
    I want to replace mine on A4 b8+ estate.
  4. Re: B8 Estate rear shock absorbers.
    1836 Post(s)
    The Passat type 3G and A4 type 8K are completely different cars, this is the reason I hate this B whatever designation, it leads to confusion. The A4 8K rear DAMPERS are quite easy to chnage but remember all the fastenings are one time only Torque To Yield AND you should NEVER replace dampers singularity, it is dangerous and should be banned like it is in other countries. Take care choosing your dampers as there are at least 16 variations depending on equipment and the OE make can be VAG's own, Sachs or Monroe.
  1. 4Motion rear Shock absorbers
    By Dave Elcome in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-06-2012, 07:37 PM
  2. Please Help Leaking rear shock absorbers on Feb 2008 Estate having only done 60K!!!!!
    By Baldone in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-04-2012, 01:05 PM
  3. Changing rear shock absorbers on MK4
    By muchos04 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-01-2010, 01:34 PM
  4. a4 rear shock absorbers
    By sbt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2009, 04:02 PM
  5. changing rear shock absorbers
    By Ventoro in forum Chat - Anything with wheels
    Last Post: 04-11-2007, 03:21 PM
