Thread: Door issues !
Results 1 to 9 of 9
  1. Door issues !
    Jun 2010
    Manchester, United Kingdom, United Kingdom
    9 Post(s)
    Hi everyone,
    My drivers door will not open (intermittently) now using the door handle. I fear that this will be a major problem if it goes the same way as the passenger door which almost never opens using the handle.
    I have VCDS... please see below. What should I do? Thanks in advance
    I scanned the car and these came up.
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0210
    Revision: 00-00000
    Coding: 0003706
    Shop #: WSC 02327 758 00200
    VCID: 2C57F4498FC0222F2B-8078
    1 Fault Found:
    02115 - Locking Unit for Central Locking
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 10
    Reset counter: 5
    Mileage: 233068 km
    Time Indication: 0
    Date: 2019.10.04
    Time: 14:08:59
    Audi A6 Avant 2.7 TDi Quattro Le Mans..... xenon, 19" alloys, bluetooth phone, satnav
  2. Re: Door issues !
    May 2014
    Darlington
    78 Post(s)
    Replace the door lock, they are a common failure.
    1 1 0
  3. Re: Door issues !
    Jul 2008
    Lisburn
    15 Post(s)
    unlock it with the key... mine done the same. put up with it for a long time now it just works.
    (stewart goes out after work and the door dosent open) lol guess it is dodgy connection that only comes to the for in cold wet weather?!?!
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
    1 1 0
  4. Re: Door issues !
    Jul 2013
    76 Post(s)
    The lock change is the only way to fix this.
    One of the 2 micro switches is failing, they are potted in the lock as such it will be a pig of job to remove the potting without causing further damage.
    Dan
    2009/2010 2.0 TDIe SE
    1 1 0
  5. Re: Door issues !
    Jun 2010
    9 Post(s)
    Quote Originally Posted by dan2485 View Post
    Any idea on price?
  6. Re: Door issues !
    Jul 2013
    76 Post(s)
    New they are around £150 depends on how good a discount that you can get.
    Try your local TPS as they may give you a deal, my local TPS has clamped down on selling to non trade buyers.
    Still worth a try before the dealer.
    Buying second comes with a risk that it maybe as bad as the one your replacing.
    Dan
  7. Re: Door issues !
    Jun 2010
    9 Post(s)
    Can anyone help me with part numbers for the driver and passenger lock.
    I have 4f2837015. Or 4f2837016 but not sure.
  8. Re: Door issues !
    Jul 2008
    Lisburn
    15 Post(s)
    7zap should keep you right. If I remember auto doc only did lhd modules. I think a passengers on the drivers woukd be ok but never confirmed. I think the passengers has an extra bit for something?
  9. Re: Door issues !
    Jul 2008
    Lisburn
    15 Post(s)
    mines now fubar'd and going by prices on auto doc the drivers one is less expensive suggesting to me there is an extra bit in the passengers one. therefore a RH side one from a LHD car will work?!?!
  1. Mk4 door issues
    By scorpio stu in forum Golf MK4 - 1999 - 2004
    Last Post: 27-04-2016, 08:27 PM
  2. Question Door handle issues
    By Saturn in forum Golf MK4 - 1999 - 2004
    Last Post: 21-09-2012, 12:36 AM
  3. Door Lock Issues
    By Jamiem in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-02-2011, 10:48 PM
  4. Door locks - issues
    By johnftr in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-02-2010, 11:00 AM
  5. Please Help MkV Door issues
    By kitoclick in forum Golf MK5 - 2004 - 2009
    Last Post: 27-09-2008, 12:36 PM
