Thread: 18001 and 01039 codes!
Results 1 to 10 of 16
  1. 18001 and 01039 codes!
    Oct 2019
    Suffolk
    Hi everyone,
    I have a passat 1.8 20v saloon,
    Trying to get it running as it should again.
    Keeps on throwing these two codes up, wondering if anyone could help please.
    I've already cleared 3 others by changing the MAF sensor, had a look round hoses quickly for any holes and changed 2 but could be more.
    Any help would be appreciated
  2. Re: 18001 and 01039 codes!
    1841 Post(s)
    Which year and engine type code, ADR?
    18001 (P1593)- Altitude Adaptation: Signal Out of Tolerance
    01039 - Engine Coolant Temperature Sensor (G2)
  3. Re: 18001 and 01039 codes!
    Oct 2019
    Suffolk
    It's a 2000, adr
  4. Re: 18001 and 01039 codes!
    Oct 2019
    Suffolk
    More bothered about the p1593 code really,
    Temp sensor is a relatively cheap fix although it's in quite an awkward place.
    Spent months working through various problems with car, just down to these two now
  5. Re: 18001 and 01039 codes!
    1841 Post(s)
    I have the old PRINTED manual at work for the ADR, our A4 loan car has the same engine... spent a lot of time on the ADR over the years. Mind you it is temporarily dead due to an air bag ECU fault and the one it needs is a 96 model year only, obsolete from Audi and 500 Euro from Germany new. Tried a used one and same fault!
  6. Re: 18001 and 01039 codes!
    Oct 2019
    Suffolk
    For its age it's not a bad car, it's my first car had it for 2 years now and served me well.
    I'm no mechanic but everything I've done so far has been fairly straightforward and not too expensive.
    Lots of help on here and a manual has seen me through it.
    Get rid of this code and I'll be happy.
  7. Re: 18001 and 01039 codes!
    1841 Post(s)
    The VAG manual does not list 18001 for an ADR of any year in Audi or VW, are you sure it is not 18010?
  8. Re: 18001 and 01039 codes!
    Oct 2019
    Suffolk
    Hi yes definitely 18001,
    Altitude adaptation signal outside tolerance
    P1593 intermittent
    Got codes using snap on ethos diagnostics
  9. Re: 18001 and 01039 codes!
    Oct 2019
    Suffolk
    It did have 18010, I reset codes and that didn't come back.
    Got coolant temp sensor on order, will see what happens when I get that on.
  10. Re: 18001 and 01039 codes!
    Oct 2019
    Suffolk
    Sorry it's an Apt, not ADR
  1. VAG Workshop Codes [WSC] - anyone recognise these UK codes please? ...
    By JulianHicks in forum VCDS - General Questions
    Last Post: 09-07-2015, 09:53 PM
  2. Help with codes
    By TREVOR 0191 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2014, 02:58 PM
  3. Question 01039 error code
    By chem1st in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-02-2010, 10:05 PM
  4. GU, RH etc. codes
    By davidcoxell in forum Golf MK2 - 1984 - 1992
    Last Post: 28-10-2009, 05:50 PM
  5. VAG codes help please!!
    By kaygolf in forum Golf MK5 - 2004 - 2009
    Last Post: 02-11-2007, 07:10 PM
