Thread: 18001 and 01039 codes!
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: 18001 and 01039 codes!
    1840 Post(s)
    Doh, I will check...
  2. Re: 18001 and 01039 codes!
    Oct 2019
    Suffolk
    Just been reading online, could I have a faulty Map sensor??
    Causing the altitude tolerance problem
  3. Re: 18001 and 01039 codes!
    1840 Post(s)
    The ELSA code table says either Air mass Meter (where did you buy it and what is it?) and yes a faulty MAP (Manifold Absolute Pressure) sensor fault could cause this issue, the only downside to this theory is that the APT does not have one....
  4. Re: 18001 and 01039 codes!
    Oct 2019
    Suffolk
    I got a second hand one, I'm guessing the MAF is good as it made a huge difference and got rid of 3 codes that haven't come back on.
    I spoke to somebody at vw today and I mentioned that a few months ago I cleaned the throttle body.
    He then told me that as soon as you move the flap inside it, it has to be reset! Does this have to be done using vagcom??
  5. Re: 18001 and 01039 codes!
    1840 Post(s)
    Yes the throttle body MUST be re-adapted to the ECU, Basic Settings 060 on drive by wire throttle bodies.
  6. Re: 18001 and 01039 codes!
    Oct 2019
    Suffolk
    OK, I'll give that a go. Thanks for your help 👍
    I'll post with results
  1. VAG Workshop Codes [WSC] - anyone recognise these UK codes please? ...
    By JulianHicks in forum VCDS - General Questions
    Last Post: 09-07-2015, 09:53 PM
  2. Help with codes
    By TREVOR 0191 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2014, 02:58 PM
  3. Question 01039 error code
    By chem1st in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-02-2010, 10:05 PM
  4. GU, RH etc. codes
    By davidcoxell in forum Golf MK2 - 1984 - 1992
    Last Post: 28-10-2009, 05:50 PM
  5. VAG codes help please!!
    By kaygolf in forum Golf MK5 - 2004 - 2009
    Last Post: 02-11-2007, 07:10 PM
