Thread: Golf Estate 2010 Fuel flap/locking help
Results 1 to 10 of 12
  1. Golf Estate 2010 Fuel flap/locking help
    Oct 2019
    blackpool
    Hi all, looked around and can't find the answer to my model/problem so looking for some help please. . .
    1. Golf estate 2010
    2. First problem was fuel tank flap door wouldn't open. . . ( I messed about after looking at help videos ) got it open and filled up
    3. Next day car central locking wouldn't open with key fob. . . opened manually and started car but fuel tank flap stuck again ( used the open/close button on drivers door a few times and fuel tank opened again )
    4. Followed another video to 'resync fob' ( switched on dashboard lights and pressed unlock on fob for 5 secs ) central locking now working but fuel flap still stuck
    I now have an open car but fuel flap still won't open but in garage at night and not too keen on locking it up again until I get some help as to what's going on, what to do. Prior to the 1st fault of fuel flap everything was working fine
    Any help would be appreciated?
  2. Re: Golf Estate 2010 Fuel flap/locking help
    28 Post(s)
    661 Post(s)
    Have a full car fault code scan done using VAG specific equipment, there may be errors in the central convenience system which will help in diagnosing the problem.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  3. Re: Golf Estate 2010 Fuel flap/locking help
    Oct 2019
    blackpool
    Thanks and does this mean a trip to main dealer?
  4. Re: Golf Estate 2010 Fuel flap/locking help
    Sep 2009
    Stoke on Trent, England
    10 Post(s)
    Quote Originally Posted by mgsontour View Post
    Last I heard dealer was charging 70 for a diagnostic scan which is expensive. Find a good garage that has VAG-COM\VCDS.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  5. Re: Golf Estate 2010 Fuel flap/locking help
    Oct 2019
    blackpool
    Thanks, I'll have a look around. . . Does the scan just reveal the issue or is it a scan/reset type of test so it works afterwards? Cheers
  6. Re: Golf Estate 2010 Fuel flap/locking help
    Sep 2009
    10 Post(s)
    VAG-COM\VCDS does a full scan to show error codes logged in the ecu. It saves a log file with the results. Each error has a priority number.
    Fault Code Screen
    Clearing error codes is generally done after a faults has been repaired. Clearing codes doesn't make everything on it doesn't fix any error codes.
  7. Re: Golf Estate 2010 Fuel flap/locking help
    Oct 2019
    blackpool
    Cheers, so my understanding is a scan will give a code, the code relates to a fault which can be fixed then reset; right?
  8. Re: Golf Estate 2010 Fuel flap/locking help
    Sep 2009
    10 Post(s)
    VAG-COM\VCDS does a full scan to show error codes logged in the ecu. If no error codes are listed for fuel flap lock then you can check this component in Advanced Measuring Blocks with many other components listed.
    Check voltage and operation, you should be able to switch it off and on. See if it locks.
  9. Re: Golf Estate 2010 Fuel flap/locking help
    Oct 2019
    blackpool
    Cheers and appreciate your help
  10. Re: Golf Estate 2010 Fuel flap/locking help
    Oct 2019
    blackpool
    I saw one of these OBD2 fault code reader
    in Aldi so bought it, plugged it in and followed instructions and after scanning came up with : No errors
    Would the
    VAG-COM\VCDS do a different scan?
    Streetwize OBDII Fault Code Reader - LCD Screen | Euro Car Parts
  1. passat b6 estate fuel flap cover
    By grahambee in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-07-2013, 11:51 AM
  2. Please Help Fuel Filler Flap 02 Passat Estate
    By ajadriano in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-09-2012, 12:29 AM
  3. Passat estate Diesel Fuel Flap
    By Chipped2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2011, 01:34 PM
  4. B5/B5.5 Estate Fuel Flap
    By Billabong in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-01-2010, 09:26 PM
  5. golf mk4 1.8t fuel flap & resercualtion motor flap problem
    By shayd in forum Golf MK4 - 1999 - 2004
    Last Post: 25-04-2008, 05:50 PM
