Thread: Golf Estate 2010 Fuel flap/locking help
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Golf Estate 2010 Fuel flap/locking help
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Quote Originally Posted by mgsontour View Post
    I saw one of these OBD2 fault code reader
    in Aldi so bought it, plugged it in and followed instructions and after scanning came up with : No errors
    Would the
    VAG-COM\VCDS do a different scan?
    Streetwize OBDII Fault Code Reader - LCD Screen | Euro Car Parts
    As I've said you need to find someone with VAG-COM\VCDS that is the only true DIY scanner for VAG vehicles. They aren't cheap but you can't make a silk purse from a sows ear. That one is a cheap generic scanner which can give false results.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  2. Re: Golf Estate 2010 Fuel flap/locking help
    1837 Post(s)
    The central convenience system is not emissions related and therefore not OBDII compatible, you have bought a scanner which will only access address 01, not 46.
  3. Re: Golf Estate 2010 Fuel flap/locking help
    Oct 2017
    London
    12 Post(s)
    I had a 2009 1.9tdi Golf Estate in recently which operated on the system that doesnt use the electronic flap open switch on the drivers door card. It uses the system where you push in and unclick the fuel flap to open it and the same to close it and when the central locking is locked the fuel flap locks with it. The one I had failed to close properly at all. Part Number 5N0810773D sorted that issue just incase anyone else has the same.
  1. passat b6 estate fuel flap cover
    By grahambee in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-07-2013, 11:51 AM
  2. Please Help Fuel Filler Flap 02 Passat Estate
    By ajadriano in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-09-2012, 12:29 AM
  3. Passat estate Diesel Fuel Flap
    By Chipped2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2011, 01:34 PM
  4. B5/B5.5 Estate Fuel Flap
    By Billabong in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-01-2010, 09:26 PM
  5. golf mk4 1.8t fuel flap & resercualtion motor flap problem
    By shayd in forum Golf MK4 - 1999 - 2004
    Last Post: 25-04-2008, 05:50 PM
