Thread: Excess Oil in lower intercooler boost pipe
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. Re: Excess Oil in lower intercooler boost pipe
    #21
    Oct 2019
    wales
    ok update, recon turbo & oil feed pipe required & fitted, starter was goosed, new starter fitted, oil & filter changed car running all electrical faults have been cleared by garage, intercooler system cleaned as much as can be, car is running fine, the oil feed pipe was partially choked starving the turbo bearing so the bearing then the seal & turbo shat themselves, but it back on the road, thanks for all the help chaps
  2. Re: Excess Oil in lower intercooler boost pipe
    #22
    Near Blackpool
    48 Post(s)
    Thanks for finishing the tale
  3. Re: Excess Oil in lower intercooler boost pipe
    #23
    Oct 2019
    wales
    ha well all is not as well as it first appeared, new reco turbo has shat itself, second turbo to do that bkd engine, garage replaced turbo, oil, filter & oil feed line, but lad drove it no more than 100 miles, sump nearly empty, smoking like it on 600 fags a minute, oil out of tail pipe and turbo appears to be leaking oil, not a happy bunny here
  4. Re: Excess Oil in lower intercooler boost pipe
    #24
    Oct 2019
    wales
    ok tale endeth ............. i think, warranty turbo after seals failed on the initial replacement one, all the oil dumped from the first turbo dump must have choked the cat and created a back pressure on the seal within initial replacement turbo, the cat was gooed up to high heaven sot internals been removed ( i know it shouldnt be, but it is for a short term) no the car runs with any excess back pressure onthe turbo & the car runs / drives great, here endeth the tale, i bloody hope
  5. Re: Excess Oil in lower intercooler boost pipe
    #25
    Near Blackpool
    48 Post(s)
    Ha jeez sounds promising! I bet it’ll still pass emissions with out a cat.
  1. Question Part number for lower intercooler S-hose?
    By Dan Williams in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-08-2016, 08:52 PM
  2. intercooler pipe
    By monkgti in forum Golf MK4 - 1999 - 2004
    Last Post: 11-03-2012, 05:37 PM
  3. oil from intercooler pipe
    By technohippy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-03-2010, 09:04 PM
  4. ARL Intercooler Pipe
    By pon in forum Golf MK4 - 1999 - 2004
    Last Post: 07-07-2009, 11:21 AM
  5. Intercooler Pipe
    By Clinterous in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-06-2009, 08:32 PM
