Thread: Excess Oil in lower intercooler boost pipe
Results 11 to 20 of 25
  1. Re: Excess Oil in lower intercooler boost pipe
    Oct 2019
    wales
    Thanks Jonathan, yes i did read somewhere they idle erattically until they relearn the default settings or something like that, ill nip now to pull off the battery as the garage chap has gone home for tea
  2. Re: Excess Oil in lower intercooler boost pipe
    Near Blackpool
    48 Post(s)
    Also you’ll get a steering fault until you’ve rolled the wheels and turned the steering wheel as the steering wheel angle sensor needs to re adapt.
  3. Re: Excess Oil in lower intercooler boost pipe
    Oct 2019
    wales
    Yes seen that on a few VWs ive had in the past, i wish it was as reliable as my 197k T5
  4. Re: Excess Oil in lower intercooler boost pipe
    Oct 2019
    wales
    Update gents, left battery off vehicle overnight to dissapate power & reset ecu but only 1 fault code has disappeared, any pointers on what next ? Im trying to get the garage to change the crank sensor and start the car on tick over just to see if the signals all in the right place , sequence or wishywashy thiking of mine
  5. Re: Excess Oil in lower intercooler boost pipe
    Near Blackpool
    48 Post(s)
    You have to clear faults stored via vcds or another tool. Leaving unplugged over night is more to let anything that’s been ****** off with low voltage reset. Still need to clear codes.
  6. Re: Excess Oil in lower intercooler boost pipe
    Oct 2019
    wales
    I think the auto electrician is out at the car i will get him to clear the codes, if he dont i can do it or recheck it with my foxwell NT 644 pro ......... yes ?
  7. Re: Excess Oil in lower intercooler boost pipe
    #17
    Oct 2019
    wales
    had word back from garage, auto electrician has said the bcm & the ecu are duds, he recommends scrapping the car, is this a bit of an extreme recommendation ? bcm & ecu can be recoded from a similar vehicle ?
  8. Re: Excess Oil in lower intercooler boost pipe
    #18
    Near Blackpool
    48 Post(s)
    No idea what a bcm is but I’ve had a failed ecu on an A4 and I bought it for Ł30 on eBay and got it coded by an independent with proper VAG VPN kit for Ł25. Worked fine after that.
  9. Re: Excess Oil in lower intercooler boost pipe
    #19
    Oct 2019
    wales
    BCM is body contol module think its the board that controls the electrics, i think hes a bit extreme to say scrap car, cost me 2k least i can do is try to hammer down on a few faults, as said previously, these issues were not present when the car broke down and only arose after taking battery off to fully charge it. I will go to the car and see if i can get some part numbers for the ecu & bcm, seen a few cars by me breaking and also there is ebay
  10. Re: Excess Oil in lower intercooler boost pipe
    #20
    Near Blackpool
    48 Post(s)
    Also a second opinion as he could just be a **** auto electrician who can’t be ***** with the hassle
  1. Question Part number for lower intercooler S-hose?
    By Dan Williams in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-08-2016, 08:52 PM
  2. intercooler pipe
    By monkgti in forum Golf MK4 - 1999 - 2004
    Last Post: 11-03-2012, 05:37 PM
  3. oil from intercooler pipe
    By technohippy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-03-2010, 09:04 PM
  4. ARL Intercooler Pipe
    By pon in forum Golf MK4 - 1999 - 2004
    Last Post: 07-07-2009, 11:21 AM
  5. Intercooler Pipe
    By Clinterous in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-06-2009, 08:32 PM
