Thread: No fog lights help for mot please
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. Re: No fog lights help for mot please
    #21
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Fuse 36 looks to be 15A in that picture, but different style and hence a replacement. Any idea why it was replaced?
    You won't get the green indicators if the relay / control module isn't sending 12V to the actual lamps - they run off the same relay outputs at pins 2 and 5. Not local supply to light in switch, for example.
    If relay isn't sending 12V out then probably one of:
    1. it isn't getting a 12V supply at pin 9 and / or 14 (check when ignition on). We know pin 4 is sending 12V to number plate lamps, so at least one supply are working. I haven't worked out which supply is for which output.
    2. it isn't providing 12V to the switches from pin 8.
    3. it isn't getting the "turn lamps on" 12V from the switches to pins 1 and 3.
    4. it is unable to switch 12V to pins 2 and 5 to supply lamps and button indicators.
    5. there is no proper ground from pin 6.
  2. Re: No fog lights help for mot please
    #22
    Oct 2019
    Hertfordshire
    I've just change the fuse to 15amp it was sitting in the spares so tried it but nothing. Is this the correct relay
    I've opened this up and looked inside and nothing is burnt out. And this is the one I replaced. Is this the correct relay for fogs
    How do I know which pins to test
    Sent from my CLT-L09 using Tapatalk
  3. Re: No fog lights help for mot please
    #23
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Erm, no. That's 4B0919471 / location 387: control unit for headlight, brake and tail light control.
    You want 8D0907701: control unit for fog lights and rear fog lights. Plenty on eBay: 8D0907701 | eBay
  4. Re: No fog lights help for mot please
    #24
    Oct 2019
    Hertfordshire
    Quote Originally Posted by VAG-Abound View Post
    Well that some up the issue I've been testing and brought the wrong item.
    Okay thanks I will get hold off one and report back with the results.
  5. Re: No fog lights help for mot please
    #25
    Oct 2019
    Hertfordshire
    Okay I got the relay 397 but where does it go I'm confused
  6. Re: No fog lights help for mot please
    #26
    Oct 2019
    Hertfordshire
    Anybody know the location off this fog relay as I'm stumped on this
  7. Re: No fog lights help for mot please
    #27
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Try behind glove box
  8. Re: No fog lights help for mot please
    #28
    Oct 2019
    Hertfordshire
    That I odd place to put it guessing I'm going to have to unbolt the glove box to get to it. Thanks
  9. Re: No fog lights help for mot please
    #29
    Oct 2019
    Hertfordshire
    Update..
    Success relay has been switched over and I now have fog lights again front and back. So it can be mot Monday. Again thankyou for the help.
    The old relay is rattling inside so assume that we'll broke but will open it up to see what exactly caused the rattle
  10. Re: No fog lights help for mot please
    #30
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Great. Really pleased you were able to get it sorted.
  1. Question vw polo 1.2 twist number plate lights n dashboard lights not working
    By gauchosanto in forum Polo - Derby - Lupo - Fox
    Last Post: 29-09-2017, 07:03 PM
  2. Question Coming home lights AUDI S3 - Query xenon to fog lights (information inside)
    By A6-MO in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-02-2013, 02:28 PM
  3. Please Help All interior lights and door lights stopped working in my Sharan 1.9 TDi (Nov 01 New Shape)
    By di4charles in forum Touran - Sharan - Caravelle
    Last Post: 09-01-2013, 01:50 AM
  4. Please Help Enabling Coming Home lights in VCDS (no auto lights fitted)
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-07-2011, 09:42 PM
  5. ABS, Glow plug, Traction control lights Flashing and no brake lights
    By bbq365 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2011, 06:15 PM
