Thread: Driver's door latch/handle sticks
  1. Driver's door latch/handle sticks
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    I had this problem last winter and now the cold weather is coming again I'd like to get it fixed!!
    The issue is that when you go out say first thing on a frosty morning the door opens fine, but if you then shut the door and open it again (from the outside) when you go to shut it for the second time the door won't latch, instead it bounces open again and won't stay closed unless you hold it shut and press the lock button!
    Is this something that can be fixed easily or is it a door card/handle off job?
    I don't even know why I asked that as nothing on a VW is easy!!!
    Any advice much appreciated as always.
    2006 VW Passat 2.0 TDI (BKP) SE Estate
  2. Re: Driver's door latch/handle sticks
    Aug 2007
    Midlands, Uk.
    Quote Originally Posted by jmurray01 View Post
    I had a similar issue with a rear door, I ended up spraying WD40 up into the door lock via the catch and through the hole behind the door handle while operating the interior door handle. I could hear the mechanism freeing up inside. Not sure if its the same issue.
  3. Re: Driver's door latch/handle sticks
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Quote Originally Posted by allan_audi View Post
    Sorry for the delay in replying. I will give this a go, thanks!
  4. Re: Driver's door latch/handle sticks
    Aug 2007
    Midlands, Uk.
    On the rear doors there is also a rubber bung near the child lock switch, if you pull this bung out you can manually reset the lock using the plastic key from your keyfob. Useful if you cant get the door to latch by closing the door or operating the handles.
  1. Driver door handle wont open door broken ....pulley rod....help !
    By Sam James in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-04-2019, 01:10 PM
  2. Driver's door handle - keyless entry woes
    By wizbongre in forum A8 - S8 - V8
    Last Post: 06-01-2015, 01:45 AM
  3. Driver door latch electronics and removal
    By ajg617 in forum Bora - 1998 - 2005
    Last Post: 22-11-2014, 02:41 PM
  4. Question Change driver interior door handle?
    By radfordvw in forum Touran - Sharan - Caravelle
    Last Post: 15-05-2013, 09:53 PM
  5. Driver's door latch adjustment
    By SebRogers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-01-2011, 09:29 AM
