Thread: Difference between 2.0tdi 108ps and 140ps
  1. Difference between 2.0tdi 108ps and 140ps
    Oct 2019
    Uk
    So I have a golf mk 6 59 plate , just wodnering what the difference between the two engines are and also if the engines are interchangeable (ie putting a 140 in a 108). Purely out of curiosity,not looking to change them.
  2. Re: Difference between 2.0tdi 108ps and 140ps
    Feb 2019
    GB
    Not sure if VW has done the same between the 110/140 and 140/170 but if yes you are probably looking at different injectors and turbo. I have driven the 110 and don't really the point of this engine over a 1.6 tdi as performance wise they felt the same.
    Sent from my SM-G950F using Tapatalk
  3. Re: Difference between 2.0tdi 108ps and 140ps
    Oct 2019
    Uk
    According to Celtic tuning the engine of both the 110/140 are the exact same just a different map. Thing is there not much info out there regarding the 110. Different people are saying different things
  4. Re: Difference between 2.0tdi 108ps and 140ps
    You can tell the difference on the road , basically the same engine so if your current 108ps unit is in good condition a simple remap will give you 140 ps .
    Looked into this with a recent Yeti purchase, the 108 I tested was very clean and okay to drive , until an immaculate 30,000 mile tdi 140 turned up
  1. Newbie question - real difference between 06/07 3.0TDi and post 08(facelift)
    By crlincoln in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-11-2011, 01:48 PM
  2. difference between 2.0tdi 143 vs 170hp
    By TigerDejan in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-10-2010, 10:00 PM
  3. 2.0TDI 140PS BKD Idle Problem!
    By gtitdi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-05-2010, 07:58 PM
  4. 2.0Tdi DSG passat sport saloon (140PS) - engine noise -
    By Mick_OC1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-09-2009, 02:37 PM
  5. 2.7tdi vs 3.0tdi - what's the difference
    By TheMatador in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-01-2009, 09:55 PM
