Thread: BLS EGR Spec and EGR Actual readings too high
  1. BLS EGR Spec and EGR Actual readings too high
    Oct 2017
    London
    12 Post(s)
    I have an early 09 reg 1.9 tdi BLS engine Mk5 Golf Bluemotion. Ive noticed the EGR spec and EGR actual are too high with both reading 365 mg/str on idle. Going by the VCDS bubble with says a max of 300. Exhaust gas duty 95.1% and car is cold.
    The car is blaming the MAF with a P0101 - Mass Air Flow (G70) Implausible Signal but I changed the MAF with another car the same I have (exact same part number) with no effect so that can be ruled out because the other car doesnt have this issue. EGR valve is clean and output test seems to show it working ok.
    Has anyone any previous experience or any ideas?
  2. Re: BLS EGR Spec and EGR Actual readings too high
    Oct 2017
    London
    12 Post(s)
    Problem solved, piston in the egr valve stuck. Hope this helps someone else with the same problem.
  1. Question EGR problem and weird actual MAF sensor readings?
    By Stavros_Davros in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-10-2017, 02:43 PM
  2. Question High readings on dash?
    By sparticus in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-05-2015, 12:51 PM
  3. Potentially parting out my High Spec B7
    By quattrodlo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-07-2013, 07:15 PM
  4. High Fuel Pressure specified vs actual
    By busandcamper in forum VCDS - Help Requests
    Last Post: 08-12-2012, 12:26 AM
  5. A3 1.6 1999 speedo and fuel gauge readings too high
    By moisty12345 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 13-10-2012, 06:55 PM
