Thread: No Dash, Parking brake stuck and no electrics on drivers door
  1. No Dash, Parking brake stuck and no electrics on drivers door
    Oct 2011
    Birmingham U.K
    Good Evening Guys
    Ive had an issue which started last night when the heavy rain started, car drove perfectly fine until i pulled up onto my driveway when everything went haywire, the dash started bleeping and saying electric handbrake fault, subsequently the dash went completely dead and the handbrake button started to flash, i took the key out and the needles on the dash started to flicker quite quickly, I restarted the car again no dash, the car started perfectly but will not move due to the handbrake being stuck on! The electrics in the driver side door are completely dead, no window movement or anything, i have done VCDS scan please see below
    Code:
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Sunday,29,September,2019,17:02:57:62939
    Chassis Type: 8T (8T0)
    Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 56 77
    VIN: WAUZZZ8T7AA003244
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: Malfunction 1010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: Cannot be reached 1100
    47-Sound System -- Status: Cannot be reached 1100
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Cannot be reached 1100
    77-Telephone -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CAHA) Labels: 03L-906-019-CAG.clb
    Part No SW: 03L 906 022 NP HW: 03L 906 019 AL
    Component: R4 2.0l TDI H20 9978
    Revision: 25H20---
    Coding: 1A194012232503080000
    Shop #: WSC 13425 002 1048576
    ASAM Dataset: EV_ECM20TDI03L906022NP A02012
    ROD: EV_ECM20TDI03L906022NP.rod
    VCID: 800FE68B1BF6581E143-80D5
    5 Faults Found:
    5608 - No Communications with Steering Angle Sender (G85)
    U0126 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Date: 2000.00.00
    Time: 00:00:00
    5615 - Door Control Module - Driver's Door
    U0199 00 [047] - No Communications
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 10
    Mileage: 219952 km
    Date: 2019.09.28
    Time: 20:09:26
    4710 - No Communications with Airbag Control Module
    U0151 00 [032] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Date: 2000.00.00
    Time: 00:00:00
    4714 - Steering Column Control Module
    U0212 00 [032] - No Communications
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Date: 2000.00.00
    Time: 00:00:00
    4715 - No Communication with Instrument Cluster
    U0155 00 [175] - -
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 11
    Mileage: 219952 km
    Date: 2019.09.28
    Time: 20:08:35
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 AK HW: 8K0 907 379 AK
    Component: ESP8 front H04 0070
    Revision: -------- Serial number: --------------
    Coding: 160504
    Shop #: WSC 06325 000 00000
    VCID: 820BEC831DFA4A0E027-80D7
    5 Faults Found:
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:08:35
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x40A6
    Hex Value: 0x122E
    Hex Value: 0x02B2
    Hex Value: 0x00FF
    01317 - Control Module in Instrument Cluster (J285)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 16
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:09:26
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x40A6
    Hex Value: 0x1232
    Hex Value: 0x0CA6
    Hex Value: 0x00FF
    01299 - Diagnostic Interface for Data Bus (J533)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 4
    Fault Frequency: 15
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:09:26
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x40A6
    Hex Value: 0x1232
    Hex Value: 0x3299
    Hex Value: 0x00FF
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 85
    Mileage: 1048574 km
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x00A2
    Hex Value: 0x0025
    Hex Value: 0x4697
    Hex Value: 0x00FF
    01321 - Control Module for Airbags (J234)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 85
    Mileage: 1048574 km
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x00A0
    Hex Value: 0x0032
    Hex Value: 0x1D97
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 DC HW: 8K0 907 064 DC
    Component: BCM2 1.1 H02 0321
    Revision: 00002001
    Coding: 031000
    VCID: 74E73A5BD74EF4BE80B-8021
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H37 0060
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H36 0042
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 10
    Reset counter: 45
    Mileage: 219348 km
    Time Indication: 0
    Date: 2019.09.10
    Time: 16:45:02
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
    Component: KLIMA 3 ZONEN H08 0160
    Revision: D0000000 Serial number: 01260520090330
    Coding: 34260000
    VCID: 76E30053C132E6AEBEF-8023
    4 Faults Found:
    01331 - Door Control Module; Driver Side (J386)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:09:26
    Freeze Frame:
    ON
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:09:26
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 12
    Reset counter: 45
    Time Indication: 0
    Freeze Frame:
    Temperature: 12.0°C
    Voltage: 13.00 V
    Output: 0 W
    Output: 0 W
    Temperature: 24.0°C
    01206 - Signal for Duration of Ignition Off Time
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 85
    Time Indication: 0
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 K HW: 8K0 907 063 K
    Component: BCM1 1.0 H25 0380
    Revision: 06025001 Serial number: 00000000387533
    Coding: 690000110034A7000005000000005F5F001D028804000141000000
    VCID: 377DCD5786B85FA6659-8062
    Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 160509 H12 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 02532C
    Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    4 Faults Found:
    02394 - Parking Light Left Front (M1)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 45
    Mileage: 1048574 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 85
    Mileage: 1048574 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 6
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:09:00
    00466 - Control Module for Steering Column Electronics (J527)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 85
    Mileage: 1048574 km
    Time Indication: 0
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 H HW: 8K0 919 475
    Component: PARKHILFE 4K H06 0050
    Revision: 11001001 Serial number: 39940914405913
    Coding: 000201
    VCID: 3E73D873A9826EEEA6F-806B
    No fault code found.
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
    Component: AirbagVW-AU10 H37 0520
    Serial number: 003EFD030VC5
    Coding: 30323433363030303030554A305238543053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 4189A38FD07C1116DBD-8014
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME4772073FI
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME4743307BD
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME662D3626L
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME342D3536H
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME622D2918%
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME622D5128$
    1 Fault Found:
    12658176 - No Communications with Steering Angle Sender (G85)
    U0126 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 85
    Mileage: 1048574 km
    Date: 2000.00.00
    Time: 00:00:00
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H16 0014
    Revision: -------- Serial number: 90319IEL0007M
    Coding: 000016
    VCID: 3D71DF7FA48475F6BF5-8068
    Component: E221 - MFL H02 0003
    1 Fault Found:
    00457 - Control Module for Network (J519)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 20
    Reset counter: 85
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:09:26
    Address 17: Instruments
    Cannot be reached
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0101
    Revision: GB500049 Serial number: 4900G09518826B
    Coding: 00CF07
    VCID: 50AF96CB0316E89E443-8005
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0125
    9 Faults Found:
    01305 - Databus for Infotainment
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 71
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:09:26
    Freeze Frame:
    Bin. Bits: 11111
    Voltage: 13.00 V
    Count: 6
    Bin. Bits: 10000
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 16
    Reset counter: 45
    Mileage: 219348 km
    Time Indication: 0
    Date: 2019.09.10
    Time: 16:45:02
    Freeze Frame:
    Bin. Bits: 10000
    Voltage: 12.80 V
    Count: 7
    Bin. Bits: 10000
    Time: 25.40 s
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 13
    Reset counter: 45
    Mileage: 219348 km
    Time Indication: 0
    Date: 2019.09.10
    Time: 16:45:02
    Freeze Frame:
    Bin. Bits: 10000
    Voltage: 12.80 V
    Count: 7
    Bin. Bits: 10000
    Time: 25.40 s
    01303 - Telephone Transceiver (R36)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 6
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:09:26
    Freeze Frame:
    Bin. Bits: 11111
    Voltage: 13.00 V
    Count: 6
    Bin. Bits: 10000
    00463 - Control Module for Digital Sound Package (J525)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:09:26
    Freeze Frame:
    Bin. Bits: 11111
    Voltage: 13.00 V
    Count: 6
    Bin. Bits: 10000
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 9
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:09:26
    Freeze Frame:
    Bin. Bits: 11111
    Voltage: 13.00 V
    Count: 6
    Bin. Bits: 10000
    03705 - Voltage Regulator
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 45
    Time Indication: 0
    Freeze Frame:
    Bin. Bits: 11111
    Voltage: 13.50 V
    Count: 6
    Bin. Bits: 10000
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 85
    Time Indication: 0
    Freeze Frame:
    Bin. Bits: 10111
    Voltage: 12.10 V
    Count: 6
    Bin. Bits: 10000
    Time: 4.30 s
    00469 - Infotainment Databus in Single Wire Operation
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 85
    Mileage: 219952 km
    Time Indication: 0
    Date: 2009.04.28
    Time: 00:00:00
    Freeze Frame:
    Bin. Bits: 11111
    Voltage: 13.40 V
    Count: 6
    Bin. Bits: 10000
    Address 42: Door Elect, Driver
    Cannot be reached
    Address 46: Central Conv.
    Cannot be reached
    Address 47: Sound System
    Cannot be reached
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
    Component: TSG BF H08 1401
    Coding: 011042325009330C03
    Shop #: WSC 02391 823 56573
    VCID: 52AB9CC30D1A9A8E727-8007
    7 Faults Found:
    00830 - Convertible Top Control Module (J256)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 129
    Mileage: 215970 km
    Time Indication: 0
    Date: 2019.06.18
    Time: 17:50:53
    01333 - Door Control Module; Rear Left (J388)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 254
    Reset counter: 45
    Mileage: 215970 km
    Time Indication: 0
    Date: 2019.06.18
    Time: 17:50:53
    01334 - Door Control Module; Rear Right (J389)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 129
    Mileage: 215970 km
    Time Indication: 0
    Date: 2019.06.18
    Time: 17:50:53
    02115 - Locking Unit for Central Locking
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 64
    Reset counter: 85
    Mileage: 215970 km
    Time Indication: 0
    Date: 2019.06.18
    Time: 17:52:37
    02111 - Motor for Window Regulator
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Freeze Frame:
    Fault Status: 00100101
    Fault Priority: 3
    Fault Frequency: 193
    Reset counter: 81
    Mileage: 215990 km
    Time Indication: 0
    Date: 2019.06.19
    Time: 16:08:21
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 160
    Reset counter: 45
    Mileage: 216261 km
    Time Indication: 0
    Date: 2019.06.27
    Time: 07:36:41
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 12
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:08:35
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0090
    Revision: 00000003 Serial number: 10000000252326
    Shop #: WSC 00000 000 00000
    VCID: 3467FA5B97CEB4BE40B-8061
    6 Faults Found:
    00576 - Terminal 15
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 85
    Mileage: 1048574 km
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.20 V
    Count: 48
    Speed: 0.0 km/h
    Hex Value: 0x0277
    Hex Value: 0x0001
    Hex Value: 0x0410
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 85
    Mileage: 1048574 km
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.20 V
    Count: 58
    Speed: 0.0 km/h
    Hex Value: 0x0277
    Hex Value: 0x0001
    Hex Value: 0x0410
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 4
    Fault Frequency: 14
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:08:35
    Freeze Frame:
    Voltage: 14.40 V
    Count: 84
    Speed: 0.0 km/h
    Hex Value: 0x02F4
    Hex Value: 0x0001
    Hex Value: 0x0410
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
    011 - Open Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101011
    Fault Priority: 1
    Fault Frequency: 74
    Reset counter: 45
    Mileage: 219952 km
    Time Indication: 0
    Date: 2019.09.28
    Time: 20:08:35
    Freeze Frame:
    Voltage: 14.20 V
    Count: 28
    Speed: 0.0 km/h
    Hex Value: 0x02E0
    Hex Value: 0x0001
    Hex Value: 0x0808
    02434 - Supply Voltage for Control Module for Left Channel
    009 - Open or Short to Ground - MIL ON
    Freeze Frame:
    Fault Status: 11101001
    Fault Priority: 1
    Fault Frequency: 83
    Reset counter: 45
    Mileage: 219348 km
    Time Indication: 0
    Date: 2019.09.10
    Time: 16:45:02
    Freeze Frame:
    Voltage: 13.00 V
    Count: 14
    Speed: 0.0 km/h
    Hex Value: 0x01E3
    Hex Value: 0x0008
    Hex Value: 0x1010
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 85
    Mileage: 1048574 km
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.20 V
    Count: 67
    Speed: 0.0 km/h
    Hex Value: 0x0274
    Hex Value: 0x0001
    Hex Value: 0x0410
    Address 56: Radio
    Cannot be reached
    Address 77: Telephone
    Cannot be reached
    Has anyone got any ideas at all as the window is stuck down and its raining quite badly ��
    I have check the fuses in the boot and also on the drivers side of the dash, all in tacked.
    Thanks in advance
  2. Re: No Dash, Parking brake stuck and no electrics on drivers door
    1835 Post(s)
    Careful there you have been giving it some boost pack haven’t you, the symptoms look like a low battery but to me more like water ingress into the electrics.
  3. Re: No Dash, Parking brake stuck and no electrics on drivers door
    Oct 2011
    Birmingham U.K
    Thank you! After a few hours of diagnosis we found that there had been water ingress in the drivers side boot area which had corroded the main power wires!
    Normal service is now resumed and the uber for the school run has been cancelled 😂
  1. Drivers door electrics failed
    By stuscfc in forum Golf MK5 - 2004 - 2009
    Last Post: 12-03-2016, 03:42 PM
  2. Drivers Door Electrics
    By nellychat in forum Alhambra
    Last Post: 21-07-2013, 07:38 PM
  3. Electrics on drivers door not working
    By lithium in forum Golf MK5 - 2004 - 2009
    Last Post: 09-05-2013, 04:08 PM
  4. Drivers door electrics misbehaving
    By lithium in forum VCDS - General Questions
    Last Post: 02-07-2010, 09:32 PM
  5. drivers door electrics
    By vinny1965 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-01-2008, 05:13 PM
