Thread: P2015 bracket didn’t work
Results 1 to 10 of 11
  1. P2015 bracket didn’t work
    Sep 2019
    Worcester
    Am I the only person in the world that the p2015 bracket didn’t work for?
    ive ordered a cheap bracket off eBay that didn’t work then I ordered an expensive diesel geek one and that didn’t work either
    If anyone can help it would be really appreciated. I have a 2009 Audi A4 2.0l tdi
  2. Re: P2015 bracket didn’t work
    Dec 2016
    IPSWICH
    i have installed a p2015 bracket and it worked as it should.Off ebay.
    I know there are 2 types depending on what manifold you have.
  3. Re: P2015 bracket didn’t work
    Oct 2019
    London
    I brought a bracket too which did not work either unsure what to do as the EML on but the arm moves back and fourth and the motor was cleaned inside too so not sure what to do
  4. Re: P2015 bracket didn’t work
    Oct 2018
    London
    Hey, What did you guys do to fix this? I have new manifold installed and also tried the bracket but the error still appears and the MIL is on
  5. Re: P2015 bracket didn’t work
    1840 Post(s)
    I will carry on from here regarding your private messages. The P2015 refers to the V157 but at some point around this time VW changed this from being the manifold flap to the inlet manifold and I need to check at work because it caught me out the first time. Which part number of manifold was fitted?
  6. Re: P2015 bracket didn’t work
    1840 Post(s)
    @Amirkhan26 So you fitted a new inlet manifold 03L 129 711 E with motor and are still getting the P2015 error?
  7. Re: P2015 bracket didn’t work
    Oct 2018
    London
    Hi Crasher,
    Sorry - didnt see that you posted here - only just did a search on the forum for P2015 and saw this thread having a new response today.
    Yes Purchased a new manifold PN: 03L 129 711 E with the Motor PN: 03L 129 086 V130 + 03L 128 063 E+ 03L 131 501 G (all came as one)
    Its installed on the car and strange enough the car has now registered 2x P2015 Faults....??
  8. Re: P2015 bracket didn’t work
    Oct 2018
    London
  9. Re: P2015 bracket didn’t work
    1840 Post(s)
    Are you sure that is new and not just tarted up?
  10. Re: P2015 bracket didn’t work
    Oct 2018
    London
    There was no gunk or anything inside - shiny and all - also had the security marks on the screws....
    The guy I bought it off did install it to his car but said something else was wrong with the car - he couldnt return it becuase it was already installed...thats when i purchased it
  1. P2015 again
    By taxi3528 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-04-2018, 09:20 PM
  2. TPMS didn't work
    By johnsimcox in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-08-2017, 12:59 PM
  3. Sidelight out, but no error & replacing bulb didn't work
    By Brycie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-02-2017, 04:20 AM
  4. The code in the manual didn't work :(
    By netjunkie in forum In Car Entertainment
    Last Post: 28-11-2008, 12:34 AM
  5. 7-plate-clutch conversion - didn't work!
    By max942x in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-02-2008, 11:42 AM
