Thread: Egr excessive flow
  1. Egr excessive flow
    May 2019
    hi
    i have a Audi A8 4.2 TDI. 2014.
    i have a EGR excessive flow fault on bank 2. So i did some live data on vcds and it is showing both air flows meters the same on tickover but as soon as you rev up,bank 2 is drawing 300mg less air than bank 1.
    so i took it to a garage who then connected it to ODIS and the technician told me he is 95% sure it is the EGR cooler. so if bank 2 air flow meter is drawing in about 300mg less air in than bank 1, it might mean the EGR cooler is blocked but wouldn't it mean that bank 2 was getting insufficient flow,not excessive flow.
    any help would be appreciated.
    THANKS
  2. Re: Egr excessive flow
    108 Post(s)
    1816 Post(s)
    It is likely the entire inlet system is clogged solid upstream of each valve, a disgusting job to do.
  3. Re: Egr excessive flow
    May 2019
    thanks Crasher for your reply..
    could you just be a bit more specific so i can get it right in my head.
    cheers
  4. Re: Egr excessive flow
    May 2019
    i tell you what the technician did say.
    performed full extensive ODIS diagnostic test plan.
    results shows EGR COOLER mechanism arm partially seized which restricts the arm lever from fully opening/closing.
    is there a arm in a EGR cooler that opens and closes.
  5. Re: Egr excessive flow
    108 Post(s)
    1816 Post(s)
    Does this car have a raised and extended glass sided roof line designed to accommodate a large wooden casket?
  6. Re: Egr excessive flow
    May 2019
    i wish it did,it would be the first AUDI A8 hearse i have seen. 0V14 YRM
  7. Re: Egr excessive flow
    108 Post(s)
    1816 Post(s)
  1. 2002 Polo 1.4 16v 100bhp - "Excessive EGR Flow" Symptoms
    By seventh-heaven in forum Polo - Derby - Lupo - Fox
    Last Post: 18-03-2013, 10:36 PM
  2. Excessive vibration Mk4 TDi
    By HalfABlueRizla in forum Golf MK4 - 1999 - 2004
    Last Post: 22-03-2011, 11:08 AM
  3. Excessive oil consumption
    By Malco in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-12-2010, 06:22 PM
  4. a6 - 2.4v6 using excessive oil
    By bigj in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-01-2010, 09:59 PM
  5. P0402 Exhaust Gas Recirculation Flow Excessive Detected
    By mr260z in forum Golf MK4 - 1999 - 2004
    Last Post: 28-03-2009, 10:11 PM
