Thread: Sulphur smell coming from vents
Results 1 to 10 of 10
  1. Sulphur smell coming from vents
    Sep 2019
    Coventry uk
    8 Post(s)
    Hello, I have recently purchased an A6 Avant 2014 pre face lift. It has the 2.0tdi engine with the auto gearbox. Full service history. Milage is currently 74000. Over the last week there has been a sulphur smell coming from the air conditioning. MPG also appears to have gone down. I have changed the pollen filter just in case but it has made no difference. No smoke from exhaust and smell from there appears normal. No obvious signs of a leaking exhaust. Its booked in to the garage on a Wednesday. Any pointers for me to let them know would be a great help.
  2. Re: Sulphur smell coming from vents
    1840 Post(s)
    Get them to stick a AC cleaner into the air box up the drain tube.
  3. Re: Sulphur smell coming from vents
    Apr 2009
    Surrey
    174 Post(s)
    Sounds like it is doing a DPF region.
  4. Re: Sulphur smell coming from vents
    Sep 2019
    Coventry uk
    8 Post(s)
    Thanks for the responses. Ill check on the air con cleaner as it seems to do it if the engine is off. Unless its an after smell still coming through. I do 500+ miles most weeks and its been there for a week so would hope the DPF regen has not stuck on! No errors displayed in VCDS. I’ll google on how to check the status of the cat to confirm if in regen.
  5. Re: Sulphur smell coming from vents
    Sep 2019
    Coventry uk
    8 Post(s)
    One can of detol disinfectant spray into the air-con intake and the smell seems to have gone away. Long journey tomorrow to confirm. VCDS confirms no DPF regen and soot load at 12%.
  6. Re: Sulphur smell coming from vents
    1840 Post(s)
    That tends to work short term in killing the bacteria that builds up on the evaporator but long term I use half a can of https://eshop.wurth.co.uk/Air-conditioning-disinfectant-spray-DISINFSPR-A-C-300ML/089376410.sku/en/GB/GBP with the tube up the drain pipe and the other half down the intake with the pollen filter out AND I know use the Mann FreciousPlus filters and these help prevent bacteria from getting onto the evaporator, after using a FreciousPlus for a year I have had no repeat of the bi annual pong.
  7. Re: Sulphur smell coming from vents
    Sep 2019
    Coventry uk
    8 Post(s)
    Crasher. I think your right. 300 mile journey today and the pong returned after a few miles. Car is in the garage tomorrow so will see what they say. Hopefully covered by warranty. Where do I find the drain pipe?
  8. Re: Sulphur smell coming from vents
    Sep 2019
    Coventry uk
    8 Post(s)
    Car was in garage today but problems with the gearbox took over. I have also emptied the washer bottle and topped up with water and a small amount of detol. 150 journey tomorrow so whom knows!
    Can washer fluid go off?
    High concentrate stuff -22 watered down 50/60
  9. Re: Sulphur smell coming from vents
    1840 Post(s)
    If washing up liquid is put into the washer bottle it can turn rancid and smell like death, the ac drains come out either side of the floor tunnel behind the tunnel heat shield either side of the gearbox.
  10. Re: Sulphur smell coming from vents
    Sep 2019
    Coventry uk
    8 Post(s)
    No smell today. So definitely will the washer bottle. No washing ip liquid just good quality screen wash.
    Thanks for all the help.
  1. Smell from air vents
    By bubak_here in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-07-2017, 12:10 PM
  2. 95 R Reg 2.0ltr Petrol, CL Sharan, juddering, loss of power, sulphur smell.
    By taki_livin in forum Touran - Sharan - Caravelle
    Last Post: 09-09-2016, 06:35 PM
  3. Please Help Smell coming through vents
    By ludikris in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-08-2011, 02:55 PM
  4. burning oil smell coming in heater vents
    By caledonianewan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-07-2009, 11:52 PM
  5. smell of petrol coming from air vents
    By bigboy in forum Polo - Derby - Lupo - Fox
    Last Post: 21-03-2008, 11:55 AM
