Thread: s4 b7 v8 coolant oddity
  1. s4 b7 v8 coolant oddity
    Oct 2009
    Ashford Kent s,e England
    9 Post(s)
    Morning all, I have had an s4 v8 avant since May this year and had no problem until now.
    Yesterday I topped up the coolant from cold as I did my regular checks, it was about 2 or 3 cm low.
    I drove approximately 7 miles at average pace, not hard or heavy.
    I then stopped for petrol and within a minute of switching off the engine noticed steam coming from under the bonnet.
    Popped the bonnet open and saw the expansion tank steaming and spraying fluid.
    Allowed to settle whilst filling up with fuel and took another look.
    All seemed fine so checked that I had not refitted the cap incorrectly earlier and that seemed fine and the level appeared to be correct.
    Drove home the 7 miles and checked under the bonnet and all seemed ok.
    In the evening checked again and all ok so set off on the same journey.Parked and waited for my daughter and decided to check again and its all fine, switched off engine and within less than a minute the same thing happened, steam , fluid burbling etc.
    Considering the fluid loss, the level didn't seem to have dropped, so drove home the 7 miles and checked under the bonnet, all ok, switched off , still ok
    At no time did the temp gauge show over normal running temp.
    Whats going on here,I am wondering about the function of the coolant tank lid being poor,why is it only pressurising after switch off.
    Audi s4 Avant 4.2 v8 auto july 2006engine code unknown
  2. Re: s4 b7 v8 coolant oddity
    Oct 2009
    9 Post(s)
    OK, just done the same trip but only switched off at the end of the journey,ie, 14 miles run, no problem, no leak etc, is it possible that I accidentally over filled the level yesterday and it has just blown out the excess, wierd
  3. Re: s4 b7 v8 coolant oddity
    41 Post(s)
    926 Post(s)
    After run electric coolant pump and fan spring to mind, causing boiling.
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  4. Re: s4 b7 v8 coolant oddity
    Oct 2009
    9 Post(s)
    Many thanks Steve, will investigate
  5. Re: s4 b7 v8 coolant oddity
    Oct 2009
    9 Post(s)
    Eventually got to looking properly and found the tank is stained pink at correct level, so getting a false indication of fluid present, also found that gubbins of the cap has collapsed and allowed the o ring to deform, thus not seating/sealing correctly.
    Ordered new tank and cap, cheap aswell at 21 from Europarts, fitting in the morning if the weather suits
  6. Re: s4 b7 v8 coolant oddity
    Oct 2009
    9 Post(s)
    All fitted, perfect
  1. Replies: 6
    Last Post: 29-11-2018, 01:41 PM
  2. Headlight oddity
    By nobbyuk in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-02-2012, 06:39 PM
  3. Sharan P REG drivers side window oddity
    By chally3 in forum Touran - Sharan - Caravelle
    Last Post: 17-05-2010, 01:25 PM
  4. Auto Lights oddity
    By MFGF in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-09-2009, 12:13 PM
  5. Concert stereo and iPod oddity...
    By omniquito in forum In Car Entertainment
    Last Post: 16-04-2009, 02:17 PM
