Thread: Reluctor Rings
  1. Reluctor Rings
    Nov 2017
    Doncaster
    Hey everyone,
    Can anyone confirm what I think I already know lol
    Does my model of passat have magnetic abs relucter rings on the front and back?
    I've been trying to fix an abs fault for a while with no success as I've had it plugged in and then changed 2 different speed sensors.
    Upon changing the back offside sensor I came across a bit of what I'm now sure was a bit of corroded abs ring that fell away from the back of the disk.
    I'm thinking now that at least the 2 rings on the wheels I've changed the sensors on are rotten and are causing the fault rather than the sensors?
    I'm pretty sure they have the rings on the front and back but the only reason I'm not sure is someone told me the back ones are built into the bearing? So then what was the bit of ring that fell away?
    I own a 56 plate 2.0 TDI saloon passat b6
    Sent from my CLT-L09 using Tapatalk
  2. Re: Reluctor Rings
    1841 Post(s)
    Yes, and they rot because they are magnetic and made from Ferous metal.
    1 1 0
  3. Re: Reluctor Rings
    Nov 2017
    Doncaster
    Cheers Crasher.
    Is it a case of caliper and disk off then drive shaft out on the front and on the back caliper, disk and bearing off?
  4. Re: Reluctor Rings
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by Dony-Jam View Post
    Cheers Crasher.
    Almost...
    Front
    How to replaceÂ*front wheel bearing onÂ*VW PASSAT B6Â*TUTORIAL | ******* - YouTube
    Rear
    How to replace a Rear wheel bearing on VW PASSAT B6 TUTORIAL | ******* - YouTube
    Auto Doc videos only show procedural and tool aspects and omit torque specs and which parts should be renewed.
    Renew hub bolt. Usual for them come in the bearing kits but not always.
    Hth.
    Mad Mitch
    1 1 0
  5. Re: Reluctor Rings
    Nov 2017
    Doncaster
    Nice one, cheers m8
  1. Replies: 1
    Last Post: 24-11-2013, 03:50 PM
  2. New rings.
    By hibbsy21 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-08-2012, 05:03 PM
  3. Spigot Rings
    By Chriseybaby in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-07-2012, 09:34 AM
  4. ABS rings
    By eddie v twin in forum Touran - Sharan - Caravelle
    Last Post: 22-01-2008, 09:13 PM
  5. The Four Rings
    By stuart in forum History - Audi
    Last Post: 08-05-2004, 09:14 PM
