Thread: Cheap diagnostic tool
  1. Cheap diagnostic tool
    May 2019
    Louisburgh
    Need diagnostic unit to turn off airbag light.it was caused from the under seat connector getting damaged.what unit can I buy that will turn the light off.I've a autel unit but it won't do the job.I've the wires soldered now so hope its sorted
    Sent from my 9008X using Tapatalk
  2. Re: Cheap diagnostic tool
    Cornish Expat Guest
    Can’t vouch for the VW version but my icarsoft 908 Volvo specific code reader has got me out of many a CEM hole. The website even has a video demo resetting an Audi airbag light. £100 ish new but my used one was half that on eBay.
    Audi, VW, SEAT & Skoda iCarsoft i908 Multi System Diagnostic Tool - SRS, ABS, Engine & Transmission
  3. Re: Cheap diagnostic tool
    Sep 2019
    London
    The i908 has been replaced by the VAWS V1.0 You also have the more advanced version, the VAWS V2.0. This website have all of the function lists.
  4. Re: Cheap diagnostic tool
    Oct 2017
    London
    12 Post(s)
    Check Ebay or Gumtree for someone in your area operating VCDS. They will turn the light out for a small fee. If you would rather buy something it depends on how often you will use it. If its going to be all the time then VCDS, although expensive, is a good way to go. I would find it hard to go back to a cheap scanner as other readings and info are often required to solve a problem. I see every day the computer blames a part that is working fine!
  5. Re: Cheap diagnostic tool
    May 2019
    Louisburgh
    Got someone to do it..sorted thanks
  1. Query re EAST VW ScanDi Tool diagnostic tool
    By sarahmac45 in forum VCDS - Help Requests
    Last Post: 15-11-2015, 05:13 PM
  2. Diagnostic tool....
    By hemang02 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-06-2009, 07:07 PM
  3. VW Diagnostic Tool
    By Evoblade in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-01-2009, 09:45 AM
  4. Diagnostic Tool
    By MediaAssassin in forum Golf MK4 - 1999 - 2004
    Last Post: 15-03-2008, 09:12 PM
  5. Diagnostic Tool.
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-04-2007, 11:42 PM
