Thread: Aircon fault - VAG diag
  1. Aircon fault - VAG diag
    Jan 2009
    Hi all,
    At the moment my air con wont come on. I have managed to get the below error codes from the car. Can anyone point me in the right direction to start in or is it simply a replacement compressor?
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 CR
    Component: Climatic PQ35 081 0404
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground
    Address 18: Aux. Heat Labels: 1K0-815-071.clb
    Part No: 1K0 815 071 H
    Component: Zuheizer 031 1312
    Revision: A Serial number: 09010046
    Coding: 0000011
    4 Faults Found:
    01415 - Recirculating Pump (V55)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 0
    Fault Frequency: 255
    Reset counter: 216
    Mileage: 203262 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 28:36:38
    Freeze Frame:
    OFF
    Temperature: 27.0°C
    Temperature: 42.0°C
    Thanks in advance.
  2. Re: Aircon fault - VAG diag
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    What engine code is it? Replacing the G65 sensor was quite easy on our AZV (basically same as more common BKD): Replacing G65 air conditioning pressure sensor on 2.0 TDI Touran (AZV engine)
    I used a Hella part from GSF. They so a cheaper one, but I wanted a brand I recognised.
  3. Re: Aircon fault - VAG diag
    Jan 2009
    Quote Originally Posted by VAG-Abound View Post
    Its the 1T BKD engine.
  4. Re: Aircon fault - VAG diag
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    AZV and BKD are identical layout AFAIK - we have one of each .
    My Hella one cost ~£30 from Parts in Motion, and they still have them: 332450349288 | eBay
  1. Aircon fault codes
    By lawsom34 in forum VCDS - Help Requests
    Last Post: 04-11-2012, 11:43 AM
  2. Aircon Fault
    By kid-jensen in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-03-2011, 02:43 PM
  3. Question Aircon fault Code
    By Evobully in forum Golf MK4 - 1999 - 2004
    Last Post: 01-07-2009, 07:43 PM
  4. Aircon fault
    By 3dogs in forum Touran - Sharan - Caravelle
    Last Post: 12-05-2008, 01:01 PM
  5. Diag fault code help ???
    By BigDave123456 in forum Audi A4 - Archive Topics
    Last Post: 29-06-2007, 11:12 AM
