Thread: Intermittent power loss Audi A3 8L 1.8T 1998 AGU engine
  1. Intermittent power loss Audi A3 8L 1.8T 1998 AGU engine
    Sep 2019
    Wilts, UK
    My Audi has an intermittent power loss and misfire. It can happen two days running, or be 2 weeks between problems.
    There is no pattern to the power loss and misfire, and occurs no matter what the speed, load or engine revs.
    There are no fault codes.
    I have had 2 garages look at the problem with no result.
    I have changed: -
    ingnition amplifier
    all coil packs
    N75 valve
    spark plugs
    petrol filter
    cleaned the throttle body.
    One of the garages carried out a smoke test to check for leaky pipes.
    Fuel consumption appears to be fine.
    When this power loss occurs the car will idle - but roughly. If it is turned off and then restarted it is fine - no more misfire/powerloss.
    This is otherwise a lovely car and I do not want to get rid of it, but I can't trust it.
  2. Re: Intermittent power loss Audi A3 8L 1.8T 1998 AGU engine
    40 Post(s)
    897 Post(s)
    Do you have a performance “cone filter” intake installed?
  3. Re: Intermittent power loss Audi A3 8L 1.8T 1998 AGU engine
    Sep 2019
    Wilts, UK
    Thank you for your prompt response.
    No, I do not. I believe the car to be in original spec.
  4. Re: Intermittent power loss Audi A3 8L 1.8T 1998 AGU engine
    40 Post(s)
    897 Post(s)
    What is being used to check for fault codes?
  5. Re: Intermittent power loss Audi A3 8L 1.8T 1998 AGU engine
    Sep 2019
    Wilts, UK
    The vehicle was first checked out at an Audi main dealer. Following that it was taken to an independent garage that had a good reputation for working with Audis. Finally it was taken to an independent BMW specialist because I was impressed with their setup, the way they worked and that they had worked well on my BMW.
    All found that the fault was not generating any codes.
  6. Re: Intermittent power loss Audi A3 8L 1.8T 1998 AGU engine
    40 Post(s)
    897 Post(s)
    OK, you need to start with a fault code read carried out using a VAG specific system such as VCDS.
  7. Re: Intermittent power loss Audi A3 8L 1.8T 1998 AGU engine
    Sep 2019
    Wilts, UK
    Thank you.
    I'll look for someone in my area that can offer this service.
  8. Re: Intermittent power loss Audi A3 8L 1.8T 1998 AGU engine
    Sep 2019
    Wilts, UK
    Is there a VAG Com section on the forum that may list specialist offering this service in my area?
  9. Re: Intermittent power loss Audi A3 8L 1.8T 1998 AGU engine
    40 Post(s)
    897 Post(s)
  1. Brief Intermittent Power Loss - Low Km 2011 Audi TTS
    By QQQO in forum TT - 8N Forum - 1998 - 2006
    Last Post: 26-01-2017, 01:52 PM
  2. Audi a6 1998 2.5 tdi power loss
    By kevsplit in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-10-2011, 10:04 PM
  3. 3.0 tdi intermittent power loss
    By jblogh in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-10-2009, 02:47 PM
  4. Please Help Audi 80 TDI 1983 intermittent power loss
    By mjcoops in forum 80 - 90
    Last Post: 17-12-2008, 09:40 PM
  5. Power loss A4 TDI 1998
    By Yosimmity in forum Chat - Completely Off Topic
    Last Post: 09-11-2006, 01:15 PM
