Thread: B6 modifications
Results 1 to 10 of 16
  1. Question B6 modifications
    Sep 2019
    Northwich UK
    After trying to search unsuccessfully for answers on my own. Obviously I知 just not entering the correct search terms and showing my novice地ess. I知 Hoping somebody will point me to where I need to go as i知 sure all my questions will have already been answered... and probably several times over (sorry everyone).
    OK so my car: 2007 B6 Passat Estate (Variant - for those over the pond) SEL 170 with factory fitted detachable tow hitch (read somewhere this may mean I have something different re the standard modules). An RCD 500 stereo and the iPod dock in the glovebox (which I can稚 seem to get to work anyway) and the mods I知 looking to do are.
    1. Swap the stereo for the RNS315 with DAB.
    I understand the parts I知 going to need are:
    RNS315 unit the one with DAB.
    Sat nav gps antenna.
    An adapter to allow me to plug in the fm/am aerial due to the closeness of the connector spacing on the back of the 315.
    Dab aerial (but what is the original and where does it actually go?)
    Microphone that goes to the rear view mirror, but up which pillar?
    and a canbus gateway due to battery drain issue unless this ok due to the tow bar fitment.
    2. Swap the midline display for the high line display (the red one not the black /white one)
    I understand parts I知 going to need for this one are:
    New high line clocks.
    Steering wheel module.
    3. Swap the steering wheel for a multi function one. (8 button one)
    I understand the parts I知 going to need for this one are:
    Either the buttons etc... or a complete wheel with them already on.
    And if I do 2 & 3 at the same time will I need to replace the stalks?
    And final questions...
    With the 315 can I get voice function working for the built in Bluetooth and sat nav?
    With the 315 can I swap the iPod dock for anything such as an aux socket or usb point?
    Are there any walk through guides on these?
    and
    Are any of these mods straight swaps or do I need reprogramming using the VCDS for all of hem and if so where in Cheshire can I get this done and at what stage of the mod will I need to do this?
    I know this is a barrage of questions all wrapped up in one but hopefully with help I will get all the answers/directions I need, so thanks in advance.
    Regards
  2. Re: B6 modifications
    May 2012
    Everywhere
    308 Post(s)
    Engine code ?
  3. Re: B6 modifications
    Sep 2019
    Northwich UK
    Quote Originally Posted by Gazwould View Post
    Engine code ?
    Sorry for my naivety but how do I find that? And just so I understand why do we need that?
  4. Re: B6 modifications
    May 2012
    Everywhere
    308 Post(s)
    Because of the strong likely hood of the engine requiring the most essential crucial mod of all !
  5. Re: B6 modifications
    Sep 2019
    Northwich UK
    Which is? I still wouldn稚 know where to find it though.
  6. Re: B6 modifications
    May 2012
    Everywhere
    308 Post(s)
  7. Re: B6 modifications
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by AEYRE View Post
    Which is? I still wouldn’t know where to find it though.
    Most likely a BMR or BMN engine although BRD are also 170ps.
    White sticker if still there under the boot carpet or in the spare wheel well - has engine, gearbox and all equipment codes fitted from factory. Might even have the injector campaign code 23H9 hand written on it or on a separate sticker to indicate the faulty Siemens injectors and loom were replaced.
    Yep first mod if not already done should be the oil pump drive mechanism and inferior balance shaft. Being a 2007 it will most likely have the gear driven balance unit. DIY around 」250 to 」300 (parts only) more if at an independent garage service due to labour, and not done at a dealership where they replace the whole balance unit for 」1400+ plus labour I believe.
    Mad Mitch
  8. Re: B6 modifications
    Sep 2019
    Northwich UK
    From sticker it states engine is BMR, from the receipts that came with the car it had a replacement gearbox put in in 2014.
  9. Re: B6 modifications
    Sep 2019
    Northwich UK
    Just found a VW letter (Lookers Northallerton) confirming the Re-call 23H9 - injectors replaced was carried out at 50420 in Dec 2011
    also got a receipt from 2014 (VASSTECH) stating:
    replace ignition switch and battery remote
    battery
    switch 3c0905843ac
    please note: fault now showing with steering column lock interlinked with ignition switch. This fault may stop vehicle from starting - Dealer job only
    and and another one (Lookers Volkswagen- Northallerton) stating:
    cr dr13
    replaced convenience Ecu and steering column unit
    rEplaced nsf door lock,
    travel rk13
    Carried out travel check
    3CO 959 433 AR z0 140875/control unit
    3CO 905 861 J str.immob
    910 238 02 Bolt
    3c2 837 015 A 140875/latch
  10. Re: B6 modifications
    May 2012
    Everywhere
    308 Post(s)
  1. Modifications... What next?
    By TamboB8 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-11-2014, 09:37 PM
  2. Modifications To Golf GT TDi 130
    By peza82 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-09-2011, 09:58 AM
  3. Latest modifications
    By SKINNYSEAND in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-08-2009, 10:09 AM
  4. A4 Modifications
    By allya in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-11-2008, 09:28 PM
  5. passat 1.8T modifications
    By timmythedog in forum Passat - Archive Topics
    Last Post: 03-03-2006, 05:37 PM
