Thread: Code new ECU
  1. Code new ECU
    Feb 2019
    Hi, this is my first post, having a headache with my 62 plate Audi A3 8P 1.6tdi.
    It's an intermittent electrical fault, at first it was throwing up a few failures on the dash, always SRS, but would continue to drive fine, then went a few months with no faults but over the last few months has got worse with nearly all systems failing out of nowhere and unable to start the car as it also believes the brake system has failed. It would then hours or a day later start fine and allow me to clear all the fault codes.
    Now though the car is pretty much stuck in this fault state and unable to use it.
    I've been recording faults with Ross Tech in the hope to find a pattern with no luck, looked at different areas to fault find as well as had a look through the forums. I was convinced it was the clocks at one point and then wiring to the ecu but both seem to check out ok.
    I now feel quite confident the ecu is the cause which leads to my main question, is there anyone able to program a new one in for me?? I'm in Reading. I'm hoping this will solve my problem or at least confirm that it's not the ecu so I can look at other possibilities.
    If anyone also has any advice or had similar issues I'm all ears.
    Sorry if its a bit long winded and thanks for any help, it will be greatly appreciated. It's really doing my head in now! 🙁
  2. Re: Code new ECU
    Near Blackpool
    48 Post(s)
    With the immobilisers etc you need the VW VPN to code them. I use a local indie who coded it for £30. He said every time he connects to the VPN VW charge him £15! There was a pre programmed sequence that we went through on the laptop after putting the replacement in and all in all took about 10 mins. I just limped it to them swapped it in the car park and they then coded it for me.
  3. Re: Code new ECU
    1840 Post(s)
    It is €10 per hour on ODIS plus the chaps time.
  4. Re: Code new ECU
    Feb 2019
    Quote Originally Posted by jonathanfenton View Post
    Thanks for the reply, £30 would be great!
    I've only just moved to Reading, I don't suppose your indie is anywhere near? Otherwise I'll get ringing round on Monday.
  5. Re: Code new ECU
    Near Blackpool
    48 Post(s)
    Blackpool sorry !
  1. Please Help Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    By mumutley in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-05-2019, 11:10 PM
  2. Replies: 2
    Last Post: 22-10-2014, 03:44 PM
  3. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  4. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
