Thread: problems starting engine when warm
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. problems starting engine when warm
    My 2004 golf 1.9 TDi will start immediately when cold but when the engine is warm it tends to take 4 or 5 seconds before the engine starts again. Any ideas please ????
    Gary
  2. Re: problems starting engine when warm
    Now I have the same problem. Did you solve with your Golf. Any idea what to do?
  3. Re: problems starting engine when warm
    May 2007
    Liverpool
    Have you had any work done on the car recently eg Cambelt??
    1998 Audi A4 2.8 V6 quattro
  4. Re: problems starting engine when warm
    Yorkshire
    Try depressing the acceleartor 1/4 inch as you turn the key, or turn on the ignition, press the acclerator to the floor, lift off, and start the car.
    Zippy
  5. Re: problems starting engine when warm
    Angus, Scotland
    Quote Originally Posted by Zippy View Post
    Does that still work on modern injection cars??
    I know it did on Carb cars, as depressing the accelerator open the carbs and squirted some fuel in, but surely the injectors won't go unless the engine is running?!??!
    Could be wrong, but thought I'd throw in my Tuppence worth
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  6. Re: problems starting engine when warm
    Yorkshire
    Quote Originally Posted by elPaulio View Post
    Paul
    This is just from my own experience of starting modern diesels when hot, both ways seemed to work well, but the 1/4 inch gentle accelarator depression was a little easier to remember. It just worth a try if there is a problem, worked for me.
    Zippy
  7. Re: problems starting engine when warm
    No, haven't done anything related on cambelt. So far 72000km.
    There is no DTC (did the VAG-COM test, everything seems to be fine).
    Depressing the accelerator doesen't work.
  8. Re: problems starting engine when warm
    I am having this problem too when warm, but first thing when cold it starts first flick of the key
    any ideas would be great
  9. Re: problems starting engine when warm
    Dec 2007
    Hi - I also seem to have this 'problem' 1.9TDiS 2005 and 50k miles. Looks like we are going to suffer in silence with the bad starting (no offence to anyone !!)
  10. Re: problems starting engine when warm
    I have the same problem on my 1999 1.6 A3.
    On a morning she starts first time every time, but if you take a short trip to the shops or drive to work, she then won't start until she has been left to 'cool down' for at least 45 mins.
    I can drag her to life if i depress the accelerator while starting but it's still pretty ragged and hit and miss. I've just had her serviced and MOT too!
    Any ideas?
  1. Engine starting problems Vag code fault codes listed
    By MCCLATCHIE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-02-2008, 10:06 PM
  2. a6 warm starting
    By doilums in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-09-2007, 01:03 PM
  3. 110 tdi se warm starting problems!
    By lastyboy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-08-2007, 02:44 PM
  4. Golf Mk2 trouble starting when warm
    By speedydan in forum Golf MK2 - 1984 - 1992
    Last Post: 10-11-2006, 01:23 AM
  5. Starting problems when warm.........help
    By olivers in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-10-2006, 08:19 AM
