Thread: 2.5TDI Tranny-Swap - Dieselpump issues. HELP
  1. 2.5TDI Tranny-Swap - Dieselpump issues. HELP
    Sep 2019
    Norway
    Hi guys. I am in desperate need for help / pointers!
    So let me explain:
    My automatic tranny gave up and i found a older donor car with manual tranny.
    Did a full swap over the weekend, but the car wont run correct anymore.
    Blue smoke, rough idle, no power and max ca 2000rpms free revving...
    -I changed the needlelift sensor because i had a code on it. No help
    -Changed the hall sensor on the crank. No diffrence
    -Locked the engine and re-timed it. Nothing
    Then after hours of talking to my loval vw dealer i ordered a refurbished pump (expensive)
    Plugged it in, threw a immo-code, so i drove it on a trailer to a Audi place (also expensive). Got it back, and now it runs just as bad, and throws more codes;
    00550: Start of Injection Regulation (implausible signal - periodic)
    00550; Start of Injection Regulation (Control Difference - periodic)
    17583: Pre-Injection Turned Off (Periodic)
    When watching the injection times it says it at either
    0.0 BFDC or 25.4 BFDC.
    Looking at it in TDI graph it ALL over the place.
    Can anyone please help me? Im at a loss, and im coming up to 6 months without beeing able to use this car ( lucky i got my Renault Kangoo backup car)
    And seeing as i live in Norway ( where everything is expensive) i refuse to drive it to the «nearest» Audi shop. Doubtful ill ever use them again btw.
    Thank you!
  2. Re: 2.5TDI Tranny-Swap - Dieselpump issues. HELP
    Jan 2019
    Suffolk
    9 Post(s)
    Isn't blue smoke usually the result of burning oil rather than a problem with injection timing or quantity.
  3. Re: 2.5TDI Tranny-Swap - Dieselpump issues. HELP
    Sep 2019
    Norway
    Yeah it is, but all this happened after i got the error codes on the injectionpump. So i higly doubt oil burning is the biggest problem i have.
  1. 2002 audi a4 2.5tdi engine swap
    By chenzen666 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-02-2016, 09:23 PM
  2. Audi A6 Allroad engine swap with inline 5 cylinder 2.5tdi
    By chirpy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-08-2015, 02:15 PM
  3. Vp44 dieselpump
    By cs.wenderby in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-02-2013, 12:01 AM
  4. 99 2.5tdi Avant Tiptronic Shock absorber swap - How difficult?
    By Phil G Watson in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-10-2011, 11:04 PM
  5. Please Help Newbie Audi A4 96 1.8 & auto tranny rev issues
    By DKatende in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-06-2010, 06:12 PM
