Thread: Self levelling/range dash light causing car not to start
  1. Self levelling/range dash light causing car not to start
    Sep 2019
    Basingstoke
    Hi
    I have an A4 cabriolet 2.0 TSi 2008 plate.
    For a while now the car does not start when it displays the self levelling/range headlight symbol.
    Google Image Result for https://www.audi-sport.net/xf/attachments/74e14afc-624c-4e0e-b667-11d2cc2dd345-jpeg.169326/
    If it does eventually start and the symbol disappears, I often have the engine management light on and the EPC light. If I turn the ignition off it often clears it and the car is fine.
    Other times when it starts the brake warning light comes on.
    It often happens when parked on slopes.
    I have tried removing the fuse for the lights, and this worked for a while, but now does not work. Sometimes playing with various switches enables the levelling light to disappear and it starts.
    Dipstick has lost its rubber seal, this caused the engine management light to be on last but was cleared with a poke or two.
    The car is currently in a car park as it would not start tonight.
    Car has been to Audi for 2 days, told it was my dash cam. They disabled it and it started for 5 days without issue. I have not used the camera since and now the problems have reoccurred.
    Any help greatly appreciated.
    Mark
  2. Re: Self levelling/range dash light causing car not to start
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Have you had your battery/charging tested? May be an under voltage issue.
    Alan.
    VW T6 150 DSG Camper £££
  1. Self Levelling Suspension Fault - Locked Suspension Yelow Warning on Dash
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2014, 05:01 PM
  2. A3 Wont start, no dash light up but good battery....please help
    By Sam James in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 09-04-2013, 01:51 PM
  3. Wanted A3 1999 1.6 light switch (side / dip / rear fog + dash brightness / range setter)
    By psynnott in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-05-2011, 07:47 PM
  4. Removed dash clocks to repair now have immo light and wont start!
    By mpk490p in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-09-2009, 09:17 PM
  5. Replies: 11
    Last Post: 07-04-2009, 03:35 PM
